07-11-2008, 08:50 PM | #1 |
Rear camaro caliper plumbing
So I'm need to hook up brake lines to the rear camaro calipers. Shouldn't be too hard, but I need a little info. What size of banjo bolt fitting does the caliper use? Also what size is the stock rear brake line, 1/4"?
I searched and search and couldn't find this. I was also surprised there wasn't an FAQ for the camaro caliper install. |
07-11-2008, 11:23 PM | #2 |
Re: Rear camaro caliper plumbing
Are you using 93-97 Camaro calipers? If so, I will measure when I get to the shop in the morning.
Alex 1971 Lil' Red 350 SBC 700R4 |
07-12-2008, 12:39 AM | #3 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-12-2008, 11:17 AM | #4 |
yeah, that would help out.
07-12-2008, 11:18 AM | #5 |
I figured it was metric. Looking at summit, about the only metric size is 10mm.
07-12-2008, 06:43 PM | #6 |
10 mm sounds about right.....
08-11-2008, 02:49 PM | #7 | |
Did you get measurements? |
