07-12-2008, 12:17 PM | #1 |
vintage air
Does anyone have a ball park idea of how much it would cost to have a vintage air system installed into a truck that had no ac originally. Thanks for any input.
07-12-2008, 12:28 PM | #2 |
Re: vintage air
A guy I used to work with charged 750 for labor only, so the grand total was about 1,800.
69 shorty w/ 67 front clip |
07-12-2008, 01:22 PM | #3 |
Re: vintage air
id do it myself. all you really need is to cut the holes for the ac vents and the rest is a pinch
07-12-2008, 07:25 PM | #4 |
Re: vintage air
How do u do the whole cutting?
07-12-2008, 08:05 PM | #5 |
Re: vintage air
just 2 circles on each side and one above the stereo, the sizing im not sure of, someone with AC can tell you that, but it doesnt seem too taxing of a process.
07-12-2008, 10:02 PM | #6 |
Re: vintage air
thanks
07-13-2008, 11:34 PM | #7 |
chevy truck fan
Re: vintage air
i installed my vintage air setup myself except for the line connections. the overall process was a grand for tha material (kit, fittings & outlets) i had them run my lines along the fender so it was a little extra but the cost for them to do it & hook everthing up was around $400. my truck is a '72 non ac truck. i cut the center hole just like the factory with factory outlet.the hardest part was the mounting of the unit.
hope this helps.... |
07-14-2008, 01:03 AM | #8 |
Trucks N Tranzams
Re: vintage air
Check out this thread...http://67-72chevytrucks.com/vboard/s...d.php?t=249479
I just did mine and I got it done in a couple of weekends. Straightforward install. Cant beat the performance.
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
07-14-2008, 08:41 AM | #9 |
Re: vintage air
^Sweet, it helped somebody
Mine's been installed for a year now and on High it'll freeze you out of the cab.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-14-2008 at 08:42 AM. |
07-14-2008, 08:50 AM | #10 |
Red Headed Step Child
Re: vintage air
I have a stock A/C system that works but I keep having to have the system recharged. Does the Vintage air just work better and is it worth swapping?
"Dinner, the perfect break between work and drunk" -Homer Simpson |
07-14-2008, 11:46 AM | #11 |
Middle-aged Curmudgeon
Re: vintage air
If you keep having to re-charge it, you have a leak. I'd suggest just getting your leak fixed and the stock system will work fine.
07-15-2008, 12:52 AM | #12 | |
Trucks N Tranzams
Re: vintage air
It did help, thanks... I think the hardest part was putting the hoses under the dash.
07-15-2008, 03:52 AM | #13 |
Re: vintage air
Try to PM board member " coolair " He's a Tech advisor at Vintage Air.
I know they do installs at the factory or at least at a nearby location... It may be worth the 4 hour drive for you to go to San Antonio to get it done...
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 07-15-2008 at 03:53 AM. |
07-15-2008, 08:57 AM | #14 |
Re: vintage air
Are you referring hooking up the hoses from under the hood to the unit? I can't tell you how many time's I said bad words because I couldn't get my dang tools under there, or I could only tighten the stupid thing 1/8" at a time
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-15-2008, 01:26 PM | #15 |
Re: vintage air
I had a guy in New Caney, Tx install my Vintage Air on a 1970 with no factory air. It's worked fine except one electrical connector slipped off about a week after the install. I described the problem and he led me straight to it over the phone and I crimped it a little tighter, put it back on and haven't had a problem since.
There's another guy in Pearland, Tx I talked to that primarily concentrates on Vintage Air installs and I heard he's really good. I was doing a bunch of other work at the same time that he wasn't real sure about which is why I decided to go with the New Caney guys, but if I would have only been installing air I probably would have gone to the guy in Pearland. As for cost, I think I figured my air was gonna run me in the $1600-1800 installed range, but I was doing so much other work under the hood at the same time, it was tough to isolate. Let me know if you want some names or numbers, I'll see what I can dig up. |
07-15-2008, 04:23 PM | #16 |
Re: vintage air
I have heard of systems costing between $800-1200 depending on the bells and whistles you want to add, but if you have the OE set-up it is cheaper to use it and just replace the parts, and the R-12 is colder than 134a. But if non-air then vintage, rod air, etc, etc there are several kits and the prices vary depending on the "stuff' some simple kits can be done for under a grand. Good Luck!
07-15-2008, 11:59 PM | #17 | |
Trucks N Tranzams
Re: vintage air
I was talking about the tubes to the vents in the dash. The drivers side tube was especially challenging. I think I will modify my ash tray as in delete it, except for the face.
07-17-2008, 10:16 AM | #18 |
Re: vintage air
Here's some pics of an underdash unit I installed in a 72 last week. Unit is Heat/Cool & Defrost!!!
WWW.freewebs.com/luckysrodandkustom |
