Old 07-12-2008, 02:10 PM   #1
longorange68
Drop kit Install and Ideas for quick turnaround
Bought an ECE 3.5-5 drop kit a few weeks ago. Very complete kit with a set of 2.5 inch drop spindles. Want to put this in myself with the help of a buddy, and I would like to minimize the downtime that I will have with this install. I am looking for a used set of upper and lower control arms that I can sandblast and paint, and get bearings pressed onto so I can remove and replace the original set quickly. I will also be getting some new tie rod ends and other front end stuff so I can be totally done with the suspension all at once. Can anybody find any fault in my logic, or is there anything I have missed? I would like some opinions on this so I only have to do this once.
1968 Chevrolet C-10, 2WD, Longbox, Vortec 350, 700R4, 3.73 gears
Good judgment comes from experience, and experience, well......that comes from bad judgment.
1968 Chevy C-10 "Longshot": Bought used from my Uncle George in 1994 and proceeding to beat the hell out of it for 4 years. Sold it. Bought it back, dumped an ungodly amount of money into it since then.
longorange68 is offline   Reply With Quote
Old 07-12-2008, 04:04 PM   #2
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: Drop kit Install and Ideas for quick turnaround
Fastest way would be to use your original control arms and just put the drop kit on. But, since it seems like you want it to be pretty, I would suggest buying new control arm shafts (upper and lower) while you're at it. Reason being is that getting the old ones out of your old control arms and into the "new" ones may prove to be a royal PITA. At least mine are behaving that way. If you have an impact wrench w/ 1 3/8" socket (upper) and 1 5/8" socket (lower), then you may have more luck than me. But those sockets are expensive(!) so I've been going at it the old fashioned way. The rest of it you should be able to do pretty quickly if everything cooperates. Just my .02. Good luck!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 07-12-2008, 04:53 PM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Your logic is sound.. a bit overkill, but effective. Just make sure you have everything you need on hand such as;
Bearing Grease
Brake Fluid
Brake Cleaner
Pickle Fork
plus all your parts with new bearings, bushings, seals, etc. Also, If you're going to replace the control arm bushings and tie-rods, you might as well replace the ball joints too.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 07-12-2008, 05:18 PM   #4
Woobie
Woobie's Avatar
A buddy of mine helped lower my truck over Memorial weekend. Got everything together, (including ball joints and sway bar), and went at it. Took the two of us right at 18 hrs total. Having never done any of this, we didn't think that was so bad. DID have to buy a new torque wrench for the u-bolt nuts though. Oh, love the look AND the ride.
Regards,
Paul
1972 c10
2000 FLHTC 126+k miles, so far
1967 BMW r60
2007 Xterra (Wife's ride)
R.I.P. "ESLL"
Woobie is offline   Reply With Quote
Old 07-13-2008, 02:49 AM   #5
longorange68
Thanks again for the words of wisdom. Dingfodgy, oddly enough my truck is from St. Helens, interesting to find someone from there posting about how to help me. I pretty much have an entire side of my family that still lives in your town, maybe I will see you driving around soon. Thanks again to all for the help.
Old 07-13-2008, 03:38 AM   #6
Riveted1
Tasty Cakes!
Riveted1's Avatar
Bearing Grease
Brake Fluid
Brake Cleaner
Pickle Fork
Yeah, that too... kinda figured you knew about that stuff tho... :-)
