Old 07-13-2008, 11:25 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Brake caliper help...
My passenger side brake caliper is locked up. I can push it back with some force and itll free up the wheel but as soon as I hit the brakes agian its locked up and wont retract. My question is, the caliper bad or do I seem to have yet another problem? The truck was drums all around and the previous owner converted the front to disk,still had the stock master cylinder also.. Any help would be great..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-13-2008, 11:36 AM   #2
DREAMS OF A 67
Step Brother
DREAMS OF A 67's Avatar
Re: Brake caliper help...
the master cylinder and proportioning valve are different for disc than they are for drums. If they have already been changed in the conversion , you most likely have a bad caliper.
DREAMS OF A 67 is offline   Reply With Quote
Old 07-13-2008, 11:49 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
I think that if it were the master both would drag and/or lock.
The 2 possiblilties are bad caliper or a bad hose. I had a 92 with a bad hose that colapsed inside and when it got hot is wouldn't let the fluid back out. The master should also be changed to a disc/drum master along with the Prop valve.
dwcsr is offline   Reply With Quote
Old 07-13-2008, 12:16 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
The drivers side rotates fine so i guess I geta new caliper and hose and be on the look out for a new master cylinder/prop combo... Thanks Guys..
MEMBER #6377
Project "7DEUCE"
Old 07-13-2008, 01:14 PM   #5
cdowns
cdowns's Avatar
i second the hose theory/have had it happen to me
Old 07-13-2008, 01:19 PM   #6
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Yep, sounds like a bad caliper or hose.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 07-13-2008, 02:20 PM   #7
steelhorse
steelhorse's Avatar
Pop the bleeder loose and if it frees up its the hose if not its the caliper.If the hoses are cracked or old it wouldnt be a bad idea to replace anyway
steelhorse is offline   Reply With Quote
Old 07-13-2008, 02:33 PM   #8
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
If you replace the caliper, put a hose on it too.
Like dwcsr said, sometimes the hose will collapse internally. You can force fluid through it when you hit the brakes, but it won't allow the caliper to relax back.
Lugnut64052 is offline   Reply With Quote
Old 07-13-2008, 06:49 PM   #9
RoadRacer
Tire Shredder Extraordinaire
RoadRacer's Avatar
It's possible that the brake fluid has water in it as well, which may have created rust inside the piston bore. The hydraulic pressure can force the piston out, but it won't release because of the rusted bore.
If you replace the caliper be sure to flush the brake fluid completely to make sure there's no chance of a repeat occurrence.
RoadRacer is offline   Reply With Quote
Old 07-13-2008, 08:53 PM   #10
truckdude239
truckdude239's Avatar
i say hose had an 89 gmc do the same thing pop ythe blleeder screw and see if the pistion will go in easy
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-13-2008, 11:39 PM   #11
FRENCHBLUE72
PROJECT 7DEUCE
Welll guys it look s like it was the caliper I replaced both hoses and still get the same thing,so it looks like imma replace the calipers next..
MEMBER #6377
Project "7DEUCE"
Old 07-14-2008, 07:12 AM   #12
chip46wis
I just bought NEW calipers from one of the big chain auto stores for $11.97 each,hoses were $18 a piece,replace them and drive with the piece of mind.
chip46wis is offline   Reply With Quote
Old 07-15-2008, 04:44 PM   #13
70rs/ss
70rs/ss's Avatar
Could be the sliders are gunked up as well? Do new ones and be sure to add the lude to the slides and all will be good, and I 5 th the hose part as I had a Chevelle do that to me, pushed the peddle then the right front was locked up!
70rs/ss is offline   Reply With Quote
