Junior Member
![]() Join Date: Mar 2005
Electric fan installed...
Well I installed the electric fan I got last year. It was the mopar unit a lot of us bought. I installed it in the bigblock shroud, If I did it again I would do some things different but it turned out ok and working great , Its 90 and humid here in Delaware . Sitting in trafic it dosen't go over 185. Thats better then the flex fan that was on it. I also used the painless fan relay kit, on at 185 off at 170 works great.
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82 12.39 @111.33 With a 180 shot nos 69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/ email fdelcoglin@hotmail.com |
![]() Join Date: Nov 2004
Re: Electric fan installed...
Very nice. I just installed a 90-95 Taurus fan on my '99 S-10 and it works awesome. On an engine as "weak" as the 2.2L I REALLY noticed a difference in the power I "gave back" to the engine by removing the heavy clutch fan. I'm strongly considering doing this to my Silverado and C-10 as well.
Oh, I also got a 1.5-2 mpg improvement in my "city driving." With "hypermilling" (coasting to stops and crap) and the new e-fan I'm getting 25mpg city with my S-10 ![]() ![]() What CFM does your fan pull?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-13-2008 at 02:26 PM. |
Junior Member
You know, I don't know .71rat may know . I think its a replacement for some V8 jeep ,Its been so long I can't remember.. The thread was [another cheap electric fan] the info maybe in there..
Looks like a 99 to 2004 Jeep Grand Cherokee. Dorman Part No. 620-010
Can you tell me how thick the fan part is? I'm trying to find a better option for my 52 Chevy car and I only have 2.5" clearance between the water pump pulley and the radiator core. Thanks. Al |
buhler,
If you're talking about the fan pictured above (from http://67-72chevytrucks.com/vboard/s...electric+mopar), then measuring the thickness at the outside diameter is 1.75". The center of the fan (about 6" diameter), is 2.75". hope this helps. daz
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
67-72 Addict!
Nice job! I want to do the same setup on mine
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
I think I just found my next mod! Thanks for the info...
Also, just called the Jeep dealer and they still have the part # - $57 out the door ![]() |
#8 | |
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#9 | |
It does. Thanks!!
Never Ending Projects
Any body have a direct link to order this fan? All I have been able to find have been the stock replacement at $100-$150, not the $50 most have bought them for.
My local dealers suck and always overcharge so I would just rather order online. Thanks!
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Looks good at 20-ft .....
Thanks to the earlier provided link in the original thread, I got mine at:
http://www.moparpart.com/ |
#13 |
Okay, I got it ordered. I guess you have to registar before you can even lookup any part numbers. I was trying to do that before without registaring.
#14 |
its all about the +6 inches
you should relocate the switch to the rad. have a rad shop put a threaded hole in it about 1/2 way up on the side in a tank.
your set up may (pbviously) work... but it isn't nearly as efficient as it can be. It's kinda like putting the light switch at the far end of the hallway. By the time you get there, ther is no reason in turning it on. |
#15 |
Out of the carpool lane.
So does this mod require a BB shroud or can I use a SB shroud?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#16 |
Always wrenching!!
i used ls1 fans camaro/corvette
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
