Old 07-13-2008, 02:43 PM   #1
19GMC63
19GMC63's Avatar
New wheels/tires & some lowering ?'s
Well, I finally got around to getting new wheels and tires...
But as you can probably tell, it's WAY to high in the front, so it's time to take action. Now, I know some of you guys will cringe when I say this, but I'm thinking about cutting the coils... maybe between 1 and 1 1/2. So what's the step by step procedure to do this? I.E. How do I measure the coils, and do the ends need to be in the factory position? Do I cut the bump stops?... and anything else I need to know.
No for the rear; I like rake, so my goal is to go only an inch or two in the rear. What's the easiest and cheapest route? I found these on brothers...
http://www.brotherstrucks.com/prodin...number=RES6372
Opinions?
thanks
19GMC63 is offline   Reply With Quote
Old 07-13-2008, 03:19 PM   #2
TimE
Hey Y'all!!
TimE's Avatar
Re: New wheels/tires & some lowering ?'s
What size wheel/tire combo is that? It looks good on there.
As far as lowering on a budget, I think Joe231 cut 1 coil and 3 inches on the front for around a 3" drop. Search for some of his posts for more info. For the rear, those shackles look like an easy way to get a 2" drop.
Good luck!
TimE is offline   Reply With Quote
Old 07-13-2008, 03:31 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Cool man.......finally got it together!!! What size did you end up w/ as far as your tires go?
For all the work to cut coils and make a sh***y ride, wait and get some conversion spindles and do your brakes at the same time.....you will take it apart again, cuz you'll hate the ride or want it lower.......probably both.
The shackles are easy.....you could also do a flip w/ some new axle perches to weld on.......little more work though.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-13-2008, 03:55 PM   #4
19GMC63
19GMC63's Avatar
I actually went with a smaller tire than I originally thought...
245/50's on Wheel Vintique 16x8 steelies. They seem wider than 245, so maybe Sumitomo measures their tires differently.
Old 07-13-2008, 04:34 PM   #5
joe231
joe231's Avatar
TimE is correct
i got somewhere between 2-3" from 1 coil plus 3 inches
the ride isn't bad
i do need to cut my bumps though,
the is only about a half inch of travel before touching the bumps
i did this "for now"
going to use 2.5" spindles and bags eventually
oh and btw, love those wheels and tires!!!
CHEVY ONLY
Old 07-13-2008, 05:18 PM   #6
19GMC63
19GMC63's Avatar
thanks Joe.
I might go ahead and cut the coils... I've got nothing to lose.
Any certain way I gotta do it Joe? I don't have a spring compressor, so I'll have to split the ball joint right?
Old 07-13-2008, 05:45 PM   #7
scotts62
One day...
scotts62's Avatar
Sweet love the wheels! They look good on it! Ya you will have to take spindle loose from control arm. You can rent spring compressors from the parts stores and when you get done you get your money back when you take it back.. or split the ball joint, and use the weight of the truck and a good floor jack and STAND clear and lower it slowly to take tention off spring.. either works but compressor is a bit safer
Scott
93 crew cab build
Project 62
Old 07-13-2008, 05:45 PM   #8
Lane
I would anchor the spring somehow before you loosen the ball joint - so it doesn't jump out at ya...
Mine were cut so much they fall out when I jack up the front and hang the tire. lol
BTW - I love your truck!
Lane is offline   Reply With Quote
Old 07-13-2008, 07:00 PM   #9
19GMC63
19GMC63's Avatar
Wait... I'm confused. Can you write a step by step on how to remove the springs without a compressor? I just want to make sure I don't F' up.
thanks a lot
Old 07-13-2008, 08:05 PM   #10
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
I just lowered my burban, I used a floor jack and jack stands. I lifted the truck up under the coil cup on the control arm and then put the stands under the frame behind the front end. Then popped the ball joint and the shock and the swaybar off. Then I lowered the jack slowly until there was no pressure on the coil. I had to whack mine with the BFH once or twice, but they just fell out with no trouble and were under no pressure. Put the new 3" coils in and jacked it back up into position and put it back together. Just take your time and be carefull, make sure to properly support your rig before you get under it. I dont care how tough you are, you cant lift a chevy (or a jeep pickup in my case) off your legs when your honky stands collapse.
kdrodworks316 is offline   Reply With Quote
Old 07-13-2008, 09:43 PM   #11
19GMC63
19GMC63's Avatar
ah, makes total sense now. thanks a bunch... I'll give it a go tommorow.
Old 07-13-2008, 10:43 PM   #12
scotts62
One day...
scotts62's Avatar
couldn't have said it better
Scott
93 crew cab build
Project 62
Old 07-13-2008, 11:34 PM   #13
kdrodworks316
KOFFIN DRAGGER
Why thank you.
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
Old 07-13-2008, 11:40 PM   #14
soba_03
soba_03's Avatar
TIre and Wheel Combo Looks GOOD!!!
soba_03 is offline   Reply With Quote
Old 07-14-2008, 05:52 AM   #15
Iron-Butt
454 club
Iron-Butt's Avatar
I like those wheels.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 07-14-2008, 09:23 AM   #16
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
KDrod is absolutly correct. These coils do not have that much tension. When you cut the 1 to 1 1/2 (max), position the cut end into the lower a-arm as it was stock. Make sure the coil stay correctly positioned as you raise the jack...this will prevent coil rubbing noise when driving.
You could cut the bumpstop, or remove it all together and install a low profile urethane style.
Another option would be to remove the bumpstop mount all-together, but for sure run shorter shocks, this will give you more travel, and a better ride.
As for the rear goes, as a rule of thumb, for every 2" of longer shackle, it drops the truck 1". So I'm assuming those shackles are 4" longer than stock (bolt center to bolt center) ??
Those wheel look really, really nice on your GMC, BTW !!!
Later
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 07-14-2008, 09:44 AM   #17
apachedaddy
apachedaddy's Avatar
love the wheel/tire combo, but just my 2 cent by looking at the pic i would watch how much you lower the rear because it looks as if the tires will rub the outer finder lip if you drop it to much. backspaceing issue maybe or just the way it looks in the pic.
apachedaddy is offline   Reply With Quote
Old 07-14-2008, 12:51 PM   #18
19GMC63
19GMC63's Avatar
thanks a lot guys, and thanks for info Chief.
The rears will be super close, but they should tuck up under. That's one reason why I'm planning to go only 2 inches in the rear. It may rub when I really jam it into a pothole, but I'm not too worried about it. The wider late model reaend doesn't help either.
Old 07-14-2008, 02:57 PM   #19
originalJD
James
originalJD's Avatar
Hi, I just want to ask if you would post pics of the process when you are finished. I will be doing this same thing here very soon as I too cannot afford to purchase a lowering kit at this time. Thanks.
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end.
http://viewmorepics.myspace.com/inde...lbumId=1709080
http://s258.photobucket.com/albums/h...e_top_view_all
originalJD is offline   Reply With Quote
Old 07-21-2008, 09:28 PM   #20
19GMC63
19GMC63's Avatar
Finnaly got around to it today... wasn't to bad at all, the ball joints gave me a little trouble but a scissor jack made quick work of them. Pic is a little dark, but here ya go.
Next are the shackles... I'm sure I'll hafve a few questions abot those when they come in.
Old 07-21-2008, 09:41 PM   #21
originalJD
James
originalJD's Avatar
Did it throw out the wheel alignment at all?
Old 07-21-2008, 09:54 PM   #22
19GMC63
19GMC63's Avatar
it definitely threw the camber in a bit... enough to get it aligned, but not enough that i'm in no rush to do so.
Old 07-21-2008, 09:58 PM   #23
originalJD
James
originalJD's Avatar
Ok. After taking a close look at mine I was thinking it might cause tow out. The camber I'm not to worried about.
Old 07-21-2008, 10:55 PM   #24
joe231
joe231's Avatar
looks nice, how much did you cut?
i have a slight camber issue also, but like was said it isn't so bad that i'm worried about it
CHEVY ONLY
Old 07-21-2008, 11:10 PM   #25
19GMC63
19GMC63's Avatar
thanks. I cut about the same as you did... 1 & 2-3 inches.
