07-13-2008, 04:23 PM | #1 |
Armrests?
Can anyone tell me what is suposed to be inside the door to accept the screws for the armrests? I removed the door paneles and there are square holes no inserts, are these still available for a 1964 c 10?Checked lmc and couldnt find anything.
07-13-2008, 04:30 PM | #2 |
Re: Armrests?
they are square nuts with a built in clip to hold them in the square hole you referred to.
sorry, i don't know of a source for them
CHEVY ONLY |
07-13-2008, 04:41 PM | #3 |
Re: Armrests?
Thanks maybe someone here will have some they dont need.
07-14-2008, 09:33 AM | #4 |
Re: Armrests?
I have the nuts on the drivers side but not on the passenger (though the holes are there). I think that's pretty common as a lot of these didn't have passenger arm rests.
My (simple) solution is going to be welding some nuts to the back of the panel. Easy easy! |
07-14-2008, 12:23 PM | #5 | |
65 - Chevy C10
Re: Armrests?
07-15-2008, 12:24 AM | #6 |
60-66 Nut
Re: Armrests?
What you need is a couple of 1/4-20 cage nuts. I've gotten them at a fasteners supply store before. I'll look and see if I have some...
07-15-2008, 11:55 AM | #7 |
Re: Armrests?
You can get the square nuts for securing the arm rests to the door from:
www.classicparts.com I have purchased and used them. They work well. I caution people from attaching the arm rests directly to the door panel, because they have a tendancy to "oil-can" when pulled on, to shut the door. By attaching them through the door panel and into the door shell, they are much more solid. Last edited by LILRED66; 07-15-2008 at 11:55 AM. |
07-15-2008, 02:49 PM | #8 |
Cantankerous Geezer
Re: Armrests?
www.classicheartbeat.com has them, too. They are listed as 67-72 Door Panel / Arm Rest Captured Nuts.
Fred There is no such thing as too much cam...just not enough engine. |
07-15-2008, 09:05 PM | #9 |
Re: Armrests?
Thanks guys i picked up some cage nuts for the 64 door armrests ,on my 67 they are mounted on the outside,do these mount on the inside on a 64? I tried them on the outside and it seemed to be to far out?
07-15-2008, 09:14 PM | #10 |
Council of the Elders
Re: Armrests?
The cage nuts are available at Classic Parts, about $.49 each.
http://www.classicparts.com/1960-66-...ctinfo/19-691/ They mount on the inside.
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 07-15-2008 at 09:15 PM. |
07-15-2008, 09:39 PM | #11 |
Re: Armrests?
Thanks i guess ill need longer screws then,it has leather door panels it must be that they are to thick
