Hey Watch this...
![]() Join Date: Sep 2007
Fuel Cap Stuck on Truck!
For some reason, the fuel cap on my truck won't release. It's one of those that you put the key in the center and when you turn it, it retracts the 'locking' fingers, or whatever the technical term for them is.
Any way, it will turn a bit but won't come off. My thought is that possibly the system is sealed and now that the tank is nearly empty, there's a good deal of vacuum which could be holding the cap on. Sound plausible? Any ideas how to make it come loose? I was thinking of loosening up the fuel gauge sender bolts on the tank and seeing if I could relieve the pressure. Anyone had to do that before? Thanks for any advice, guys!
What have I gotten myself into now? 1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress 2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids |
KOFFIN DRAGGER
Re: Fuel Cap Stuck on Truck!
If it is a vacume, just crack the hose clamps at the filler neck, it wont take much. I am betting the your cap is just worn or gone to crap, in which case a hammer with make short work of it, Or just take a chisel or somthing and pop the tumbler out of it and it will come right off.
One day...
Ya try warming it up with a torch
![]() ![]() Mine did that same thing to me i ended up using a big pair of channel locks to break it, and bought new one with better vent. |
#4 | |
Hey Watch this...
One day...
Is it a metal or plastic cap?
Hey Watch this...
Metal... looks JUST like this one.
283 Drama Queen
![]() Join Date: Dec 2004
Yeah, the guy that ripped my truck off had the same problem, cause I still had the keys. Rather than releasing the connector tube, pulling out the neck assembly and simply putting a long screwdriver down to the tabs - while turning the key (which he didn't have) to get the cap off - he just used a mungus pipe wrench to twist the locking gas cap off.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
Hey Watch this...
Great ideas. I think I'm going to have to see about removing the filler neck from the tank. It looks like it's attached directly to the tank with a couple of bolts. Also, a couple of hose clamp-ish operations on the neck itself. I think that the PO had removed the tank recently to paint the cab (it's got fresh white paint behind the tank, and the tank is a nice shiny red), so hopefully the neck isn't hermetically fused to everything.
One day...
Thats cool, maybe it will be easy to get loose once you get into it.. good luck
Cantankerous Geezer
I would bet the filler neck hose needs replaced.
And if you have too much trouble getting the cap off, heat the tank until the cap blows off from the pressure. ![]() ![]() And if you're married your wife might want to buy some more life insurance. ![]()
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Just think of the dollars you will save on gas if you leave it stuck!
283 Drama Queen
Ah - you'll be fine. I'm using my old metal neck as a pencil holder on my desk at work. Classic Industries has the rubber hose (extra-heavy-duty) on their site and I found a 1/4" drive ratchet, a universal and a short socket worked perfectly.
Just remember that the old hose has probably become one with the tank and if you give it a good squirt with brake cleaner it will break the bond. Just watch your paint. I loosened my tank straps and that helped me get to everything easier - both out and back in - with the filler assembly. ![]()
