07-14-2008, 12:33 AM | #1 |
hooking
how can i get my truck to hook like you guy on here.what do i have to do.please help me out
07-14-2008, 12:41 AM | #2 |
Re: hooking
what kind of a setup are you running? we cant really help you without that info
1970 c20 converted to c10 sleeper 1979 c20 the wood hauler 1991 honda civic daily driver spray and pray baby |
07-14-2008, 01:30 AM | #3 |
Re: hooking
i have a 388 with 195 canfield heads,eagle crank,6inch rods,350 turbo trans with 3000to 3500 stall.cam is a comp solid roll witth 586 lift with 1.6 rockers
07-14-2008, 01:31 AM | #4 |
Re: hooking
Well high heels, short skirt, wait wrong hooking sorry.
First start with a good set of slicks, or if need be, a ET Street, or QT Pro. That is the most important thing to start with. Even if your peg legging it, very important to have item if your going to drag race.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
07-14-2008, 01:34 AM | #5 |
Re: hooking
lol
07-14-2008, 01:36 AM | #6 |
Re: hooking
i want my truck to still be streetable,but i want to be right for race day if i wnt to be.my truck is a 71 c-10 swb with trailing arms on it.i have droped it 2 inchs in the front and 5 inches in the back
07-14-2008, 01:49 AM | #7 |
Re: hooking
well i do own some slicks but i havent ran them on the truck yet.i just not to long put the motor in the truck,im kind of still working the bugs out of it.everyone i talk to tells me that its to much motor for the truck.to put it in a car.but i keep telling them about you guys on here with your trucks.i talk to dj race awhile back in phox city drag strip and he told me to go with some coil over shocks,and that will help me out alot..he tell me that he had a buddy that had some that he wanted to sell,but he never got back to me.i relly want to prove these guys around here wrong about theses trucks.so guys please help meout....I know i dont have those big moster motors like you guys do.but right now i want a little show and go truck.i want it to be so clean and sharp,that i person wouldnt think i will race it.but it will be the frist thing there on race day.then again my wife will like to drive it from time to time
07-14-2008, 02:13 AM | #8 |
Re: hooking
Next best thing for a dual purpose tire would be M/T Drag Radials, but they'll wear fast. Other then that move all the weight that you can to the back, fuel cell, battery mount them under the bed if you want to use the back. Like DJ said an adjustable coilover for the back, drag shocks in the front. Pretty much same as a car set up for drag racing, just alot harder to get the weight of the nose. And tell your buddies there's no such thing as too much power for a truck!
07-14-2008, 02:28 PM | #9 |
mini truck racer
Re: hooking
I agree , no such thing as to much power .Your motor combo sounds good . Weight transfer is key to making a truck hook up . What gear does the truck have ? Is it posi track ? Does it spin ? What do your 60' times look like ?The first 2 things make a big differece,as does tire chioce . The beuty of having a truck is you can load the bed with a jack and a pair of slicks and change them @ the track .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
07-14-2008, 04:14 PM | #10 |
Re: hooking
Thats True..
07-14-2008, 04:16 PM | #11 |
Re: hooking
how do you go by makeing the weight transfer
07-14-2008, 05:04 PM | #12 |
Re: hooking
You just need the shocks and shock mounts DJ talked to you about . You have the weight transfer built in with the trailing arm setup . Drag race suspensions ie: a 4 link go by the instant center (this is the point where the upper and lower bars would intersect if they were long enough to come to a point) The trailing arm is just as good as any drag setup it just has to be refined a little . Read DJ's thread end to end and You should be able to figure it out . Or take your truck to DJ and and have him do it for you ....lol He needs to fund the new killer motor !
NHRA Super Street 469C It only runs 10.90 at 156 mph |
07-14-2008, 05:11 PM | #13 |
Re: hooking
thats what i wanted him to do put he never got back to me about it
07-14-2008, 05:21 PM | #14 |
Re: hooking
I was joking about him doing it , I dont know if he would want to take on outside work like that . If you know anyone capable to help you it shouldn't be to hard to setup . No offense DJ.
07-14-2008, 05:48 PM | #15 |
Re: hooking
any pics on how to do it?what shocks should i use?will i still use the springs that r up under my truck now?
07-14-2008, 06:23 PM | #16 |
Re: hooking
You would do away with your stock springs . Thats what a coilover shock does . ( I'ts a spring and a shock all together ) . I believe there are plenty of pics on the thread of DJ's about the 67 Dragtruck.
07-14-2008, 10:07 PM | #17 |
Re: hooking
I have a set of drag radials for 150.00 with 12 passes on them. I could get you a deal on a set of shocks installed and a locker style posi if you don't have one.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
07-14-2008, 10:32 PM | #18 |
Re: hooking
the tires idont need,but thanks.But the shocks and the posi i can really use
07-14-2008, 10:43 PM | #19 |
Re: hooking
I would take 200 for the locker style posi. I will have to call to get you a price on the shocks. Would you want them installed?
07-14-2008, 10:46 PM | #20 |
Re: hooking
how much well it be to get them installed?and will i have to cut my bed to make them work?and do any gears come with that locker?
07-14-2008, 10:48 PM | #21 |
Re: hooking
and would i have to change the shocks and springs on the front too?
07-14-2008, 11:15 PM | #22 |
Re: hooking
you can leave the front or now.
If you don't have to have the truck real low you can keep the stock bed floor.
07-14-2008, 11:47 PM | #23 |
Re: hooking
If you do some searches, you can find some posts where I talk about stored energy and adjustable rear control arm brackets. IMO you don't need a coil over set up to make these truck work.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 07-14-2008 at 11:47 PM. |
07-15-2008, 12:02 AM | #24 |
Re: hooking
super73 your truck is move down that track.what do you have in that thang?
07-15-2008, 01:45 AM | #25 |
Re: hooking
347ci LS1. Most those passes in the video are on the motor. I didn't make a good clean N20 pass as I need to tighten up the front end. Should move pretty good on the 300 hit.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
