Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-14-2008, 12:54 AM   #1
GMC70c20
converting a longbed to a short bed
Ive seen people do this but I dont know how to do this. I have to replace all the rear corssmembers do to rust and I am going to replace the rear end, springs and relocate the shocks so i figure I may as well shorten it up. Im going to try to find a short box instead of cutting up my long box. How and where do you shorten the frame to convert it?
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 07-14-2008, 02:42 AM   #2
Couch
Daily Driver
Couch's Avatar
Re: converting a longbed to a short bed
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
this should help. good luck
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 07-15-2008, 03:15 AM   #3
GMC70c20
Does the 12" have to come out fomr under the cab" or can it come out from right behind the cab?
spray and pray baby
Old 07-15-2008, 07:33 AM   #4
djracer
djracer's Avatar
you need to come south and get a rust free short frame. I don't have one at the moment but I'm sure I can find you one!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-15-2008, 11:11 AM   #5
JMurray
I'm taking mine out from behind the cab. I am building a 4 link so I see no reason to cut the usual section under the frame. Also the section I am cutting is the wide section of the frame above the axle doing that I will gain about 2" on each side for more clearance. Just my .02
JMurray is offline   Reply With Quote
Old 07-16-2008, 02:02 AM   #6
GMC70c20
I'm just going to pull the cab and take it out from there. A local blasting shop will blast and powder coat my frame for $300.
spray and pray baby
Old 07-16-2008, 06:27 AM   #7
PA-IndianRider
PA-IndianRider's Avatar
300 bucks !!!! That sounds like a good deal to me.
As I read your posts I keep thinking what's ahead for me with my C10. Although my C10 is already a shortbed my plans to do a back half, narrowed 9" F**d rear end with ladder bar setup & "alter" the wheelbase by moving the rear axle 5" forward I will be watching this thread closely.
Good luck, take your time and post lots of pictures.
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 08-16-2008, 06:45 PM   #8
Ford Assassin
Ford Assassin's Avatar
Damn, I am I wish I could find that here!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
