07-14-2008, 07:20 AM | #1 |
Newer master and booster on 69?
I stripped a 85 2 wheel for the front parts for my 69 step rebuild.I used the spindles A-frames ect ect from the 85. I was looking at the difference in the masters and boosters from the years (I have a 1971 setup for master-booster) Is it a relatively easy swap to use the 85 master and booster---anyone have first hand with this swap? What rod did you use from the pedal to the master? any mods to this?
07-14-2008, 09:06 AM | #2 |
The Older Generation
Re: Newer master and booster on 69?
Might be some info you can use in this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=215980 It is located in the Truck Tech FAQ. LockDoc
07-14-2008, 09:21 AM | #3 | |
Retired Air Force Veteran
Thanks for that link on the Booster, M/C. That was a great build thread.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
07-14-2008, 09:48 AM | #4 | |
No problem Harry, There is a lot of good information in the FAQ forum. LockDoc
07-14-2008, 09:51 AM | #5 |
Very True. Again, Thanks
07-14-2008, 11:21 AM | #6 |
Took this pic at a local car show and this is a setup off of an early 80's P.U.
Guy siad it was a direct bolt in and just had to adjust the rod to the pedal |
07-14-2008, 11:30 AM | #7 |
Thank you VERY much----all of you----I cant say enough what a great bunch of people here!!!!
07-14-2008, 08:29 PM | #8 |
Hellasick
you didn't say if you had a manual or auto, big difference. there is an interferance issure with the auto linkage. feel like i'm tooting my own horn, but here is how i did mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=238199
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
07-15-2008, 03:47 PM | #9 |
My wonder is why not use the OE master/booster as it will fit with the 85 stuff and not need to be "fitted" I understand having the parts and wanting to use/save $$$, but a used master is kinda risky. The aftermarket sells smaller booster set-ups for these if interference is an issue, but other than a smaller diameter booster I don't see any advantage to any other MC/Bosster over the OE unless you get into a bigger bore size to improve the clamp load, but again OE works great with no issues?
