4-speed trans. crossmember ?
Is there a difference between a 4-speed trans. crossmember for a V-8 and a 6 cyl. ? Or are they the same. I have been trying to wrestle in a 6 cyl. one when I heard there was a difference. 68350 has one posted in the Parts For Sale (V-8), but it looks exactly like my 6 cyl. mount.
http://67-72chevytrucks.com/vboard/s...d.php?t=299166 Anyone no for sure? |
Junior Member
Re: 4-speed trans. crossmember ?
We just put a l6 with a granny 4 speed in a frame that was setup originally for a V-8 with a 3 speed without a problem.
The cross-member that was in the frame was riveted in so I know it was original. The transmission does not attach to the cross-member, the bell housing does. We did have to put the l6 engine in first and then mount the transmission on it from underneath. I sure hope this helps. Danny |
Did you use the crossmember that was in the truck originally?
Middle-aged Curmudgeon
They're the same.
I changed a '68 from an I-6/three-speed to a V-8/four-speed with no problems at all. An easy, no-problem, bolt-in swap. Incidentally, that trans crossmember setup looks exactly like what GM used in their medium duty trucks (school buses, U-Haul trucks) for many years. Same bellhousing trans mount, same Z-bar/push rod setup, etc. Another testament as to why our trucks have lasted so well all these years and are still motivating down the road. |
I just went and tried again. There's no way my x-member is going in except in the 6 cyl. position. You can put a V-8 4-speed in the 6 cyl. position but it puts it up against the firewall.
![]() Join Date: Jul 2004
The crossmembers for a manual tranny, with the bellhousing bolting to it, mount on different spots on the frame, depending on either I6 or V8. IIRC, because of the way the frame starts to curve in that area, the crossmembers are not interchangeable, they look very similar of course, but sounds like you need the correct donor xmember, rivits cut carefully and then bolt it in.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Junior Member
I guess we were lucky when we put the l6 in with the 4 speed transmission.
The previous owner said it was from a '69 and he thought it was from a truck that had a V-8 with a 3 speed. I am sure glad the previous owner was wrong because the engine and transmission fit perfectly. Danny |
#8 | |
#9 | |
Sorry if I disseminated some bad information. ![]() |
Hey no problem. I just wanted to get this strait. I started on this last fall including a frontend changeover, all I got done befor the cold was the frontend. Here it is the middle of summer and I'm chasing parts again.
Yeah a v-8 will drop in using the 6 stuff, but it needs to be in the same location, so the SBC will be forward a bit. If you move it back you'll need to shorten the drive shaft as well, probably not a big deal but worth mentioning. Probably $75 or so at a driveline shop.
