Old 11-11-2002, 10:44 PM   #1
LS1 K-5 Blazer
12 bolt problems
Alright, can't find a rearend for my 71. So I was pulling this one out to take to the local 4x4 shop to have them do rebuild bearings and such. So I go to pull the axles and notice the head for the bolt to remove the pin that holds the axles is gone. WTF do I do now? So does any one have a good carrier laying around that they want to sell me?
Mike Friend
2004 Chevy Silverado 4x4
1971 K-5 Blazer
LS1 K-5 Blazer is offline   Reply With Quote
Old 11-11-2002, 10:48 PM   #2
Johns70
Johns70's Avatar
OPEN DIFF OR IS IT A LOCKER?
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 11-11-2002, 10:50 PM   #3
LS1 K-5 Blazer
That means I can see the spider gears right? Basically limited slip?
Mike Friend
1971 K-5 Blazer
Old 11-11-2002, 10:54 PM   #4
mikep
Used to have a truck
mikep's Avatar
What ratio are you looking for? 6 lug axles?
No truck :-(
mikep is offline   Reply With Quote
Old 11-11-2002, 10:54 PM   #5
Johns70
Johns70's Avatar
YEAH OPEN DIFF. IS YOU CAN SEE THE SPIDERS NO SPRINGS.
LIMITED SLIP HAS THE SRINGS IN THERE WITH THE SPIDERS.
Old 11-11-2002, 11:02 PM   #6
LS1 K-5 Blazer
6 lugs, gotta count the teeth so I can figure out what gears it has. So since I can see the spiders with no springs what does that mean? I am truly rearend defficent. I actually found a 72 K-5 in Tacoma today, they wanted 325 for the whole rearend, kinda steep. I have seen 73s and up go for 150 to 175.
Mike Friend
1971 K-5 Blazer
Old 11-11-2002, 11:09 PM   #7
Johns70
Johns70's Avatar
WELL IF YOU HAVE OPEN DIFF THEN YOU DON'T NEED TO TAKE THAT BOLT OUT THAT HOLD THE PIN IN.PUSH THE AXLE ALL THE WAY IN AND THE C-CLIP SHOULD FALL OUT YOU MAY HAVE TO POKE AROUND THE CLIP A LITTLE WITH A PRY BAR OR SCREW DRIVER TO CAOX IT OUT. THE GEAR RATIO IS STAMPED ON THE RING GEAR IT WILL BE TWO NUMBERS THEN TWO DOTS AND TWO NUMBERS AGAIN. THE FIRST ONE WILL BE THE PINION GEAR COUNT AND THE SECOND WILL BE THE RING GEAR COUNT,THEN YOU JUST HAVE TO DIVIDE.
Old 11-11-2002, 11:20 PM   #8
LS1 K-5 Blazer
14..43. 3.07s does that sound right?
Mike Friend
1971 K-5 Blazer
Old 11-11-2002, 11:26 PM   #9
Fast68Chevy
Fast68Chevy's Avatar
you can punch the lock shaft out and as for getting whats left of the lockpin out by using an EZ out unless someone else knows a better trick, you wont be able to push in shaft in far enough ot remove C clip unless the lock shaft is removed, if it was able to be removed without removing lockshaft then we would have big problems..
good luck
Fast68Chevy is offline   Reply With Quote
Old 11-12-2002, 12:55 AM   #10
Brad
Out of the carpool lane.
Brad's Avatar
Sent you a PM.
ps.- I just sold the drums though.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 11-12-2002, 01:09 AM   #11
bigjimzlll
bigjimzlll's Avatar
doesnt that work out to 3.25-1
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 11-12-2002, 02:29 AM   #12
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
Drill it out and use a bolt extractor. You should be able to salvage the unit easily....
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
