Old 11-11-2002, 10:46 PM   #1
LS1 K-5 Blazer
73 and up 4x4 12 bolt in a 72 and earlier?
Can it be done? It looks like you just have to move some brackets. Any help once again would be greatly appreciated.
Mike Friend
2004 Chevy Silverado 4x4
1971 K-5 Blazer
LS1 K-5 Blazer is offline   Reply With Quote
Old 11-11-2002, 10:50 PM   #2
Johns70
Johns70's Avatar
IF I REMEMBER RIGHT 73 UP REARS ARE 1 1/2 INCHS WIDER ON EACH END.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 11-12-2002, 08:45 AM   #3
Blazer1970
Blazer1970's Avatar
And the spring pad spacing is wider. Shock mounts are wrong also. Spring pads and shock mounts can be changed quite easily though.
Blazer1970 is offline   Reply With Quote
Old 11-12-2002, 09:10 AM   #4
Fast68Chevy
Fast68Chevy's Avatar
73-up 1/2 and 3/4 ton 2wd and 3/4 ton are 42.5" spring pad spacing and so are 2wd 1/2 and 3/4 ton 64-72 except for longhorns
only difference is one shock mount which is easily modified, get tape measure out to measure to make sure on dimensions
70-72 axles are wider than 73-up light duty 1/2 ton axles by about 3/4"
57" plate to plate in 70-72 and about 56 1/4" in 73-up
good luck
Fast68Chevy is offline   Reply With Quote
