Old 07-14-2008, 12:14 PM   #1
leprcon
questions on bagging my blazer
i am looking to bag my k5, i was just wondering if the bolt on stuff from airride or kp would bolt on my blazer the front is easy just wanted to get the rear low
leprcon is offline   Reply With Quote
Old 07-14-2008, 03:10 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: questions on bagging my blazer
Are you talking about the front or back? If you are talking about the front then that is easy all bolt on, but no one that I know about makes a bolt on kit for the back.
Here is a place that sells air stff at a very good $$
http://www.*****************/index.php
Hope that helps..
tvblazer78 is offline   Reply With Quote
Old 07-14-2008, 04:29 PM   #3
leprcon
the rear was what i was talkng about. the front is easy i just didn't know if they were somewhat the same frame. if not i will just flip the springs and notch it
Old 07-14-2008, 08:28 PM   #4
HAVA79
Master Blaster
HAVA79's Avatar
I could not find any "bolt on" rear components, I went with air ride 4 link. It was pretty straight forward, just be sure to triple check your measurements!! If you are going to keep the fuel tank in the rear(no where else to put it) it gets pretty tight for the pan hard bar and exhaust/fuel tank....Also look into notching the frame at the same time-wish I had done that now.....
HAVA79 is offline   Reply With Quote
Old 07-15-2008, 07:20 PM   #5
lownfast
Gettinlow & Goinfast
Just Body Drop It And Call It Good!!
Protouring Texas built rides-
78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390
71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html
70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo-
85' C20 crew, 5.3/6L90/S475 turbo-
68' C10 5.3/4L60/Level 2 coil overs
Facebook- Protouringtexasdotcom
Instagram- @Protouringtexas
lownfast is offline   Reply With Quote
Old 07-17-2008, 12:20 PM   #6
leprcon
do you know if a bolt on 4 link will work for a blazer? i was told you would be the one to ask
