Old 07-14-2008, 10:45 PM   #1
mxracer55
Front End for 1969 C-10
Hey everyone, I just joined this site in hope to get some advice. I'm restoring a '69 C-10 from the frame up. I'm working on suspension set up right now, and I'm curious to the best method for the front end. In the rear I simply put in some McGaughy's 5" progressive rate drop springs. I'm hoping to acomplish a 4"-5" drop in the front, and I'm curious as to the different methods you can use. I also have a '67 Mustang which they make a complete front end kit from Total Control, set up with Rack and Pinion coal over shocks, upper lower A-arms the whole 9. I was wondering if you know of any companys that makes a system similar to the one mentioned above, or if you have any recomendations to help me achieve my goal. Thanks Ray
mxracer55 is offline   Reply With Quote
Old 07-14-2008, 11:06 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: Front End for 1969 C-10
Welcome ....
Might want to get the mods to move to correct forum where I'm sure you will get an answer to your question...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 07-15-2008, 02:34 PM   #3
Riveted1
Tasty Cakes!
Riveted1's Avatar
There are lots of possibilities here. You can go from no cost (cutting springs), to mid-priced (spindles, springs, disc brakes) to higher priced (air suspension). There are some custom setups too... Nathan Porter builds a custom front crossmember for these trucks, and I'm sure there are a few coil-over setups running around. Getting a 4-5" front drop can be painfully easy and cheap, or require some work and $$.... just depends on how you wanna do it. I find the search function works wonders here
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 07-16-2008, 03:11 AM   #4
mr48chev
mr48chev's Avatar
As far as replacement cross members the Porterbuilt unit was the one I was going to suggest. It isn't a budget priced item but it solves several issues with lowering this model of truck.
You probably get 4-1/2 inches of drop pretty easy with a combination of dropped spindles and custom springs.
There was an article in one of the custom pickup rags a few years ago about a kit to notch the cross member to lower the frame rails an inch and a half into the crossmember. This would lower the truck an inch and a half with no suspension mods. It amounted to a pair of c channels to fit the cutout in the crossmember with holes drilled to match the original bolt holes and either a plate or instructions to raise the brackets for the upper control arms an inch and a half. you would also have to shorten the motor mount bracket an inch and a half. It would be a lot of work to do though for that inch and a half.
