Son of a gun
SB manifold heat stove and tube FS
This is not a perfect shield by any means. There is some rust on the rear side of the outer half. To be honest though, it does not show when installed. I did not know it was rusty till I took it off. There is also some rust through around the larger mounting hole (nothing a washer tacked on wouln't fix). It should clean up pretty good.
The tube is great. The inner half is pretty good too, and all but one of the little sheetmetal screws are there. I'll take $25 INCLUDING shipping to the Lower 48. Paypal prefered, I will take a postal M.O. though. If nobody wants it I'll throw it on the next slow boat to China.
Bill BEATERS ARE NEATER |
Re: SB manifold heat stove and tube FS
Any idea how closely the tube is compared to the riser tube for the 6 cylinder set up? It look like it might be close (hard to tell from memory) - if it is, mt man chad might be interested.
ehhh... on second looks, I think it's a bit "stretched longer" than the 6.....
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! Last edited by Luvlegs; 07-15-2008 at 09:35 AM. |
Pardon my ignorance but mine was gone when I got the pickup, but is that for the ram horn manifold?
