Old 07-15-2008, 02:36 AM   #1
rcbildr
rcbildr's Avatar
Front Brake Hoses
I have an 85 Suburban with a 4" lift and I've been working on getting it ready for off road. My friend has an 83 K5 Blazer he bought with a 4" lift too and he's been asking me about the front brake hoses. Mine are stock and his look like they are the stock length too. Are extended brake hoses required or just nice to have. Is there another alternative to buying hoses...like a relocation bracket or something? Any help will be greatly appreciated. Thanks!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 07-15-2008, 09:00 AM   #2
tobiahr
tobiahr's Avatar
Re: Front Brake Hoses
I ran a 4 inch lift with stock brake line with no problems, but I never really pushed to full flex either. Mostly mud bog and river runs. I have heard that 4 inch and below is ok without modifications. I looked but could not find the Brake Line Relocation Bracket sold separately so longer lines may be your only option if you are worried about binding. If you are running larger than stock wheels I recommend braided hoses anyway to help with brake pressure. I have run stock and braided and you can definitely tell the difference in pedal feel.
tobiahr is offline   Reply With Quote
