Big Red & Mister Blue...
Clutch question
Does the contact of the clutch with the flywheel bolts cause chatter or any other issues, even remotely?
Thanks.
K10 1967, SM420 & Rockwell T221 ![]() C1500 1991, 305 CID, Ext Cab, Full Size bed, everything original except air cleaner. |
Re: Clutch question
I have not seen the clutch contact the flywheel bolts on any vehicle when properly installed. It should not
contact the bolts. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
![]() Join Date: Sep 2005
Re: Clutch question
the disc should not touch the bolts if it does the disc is in wrong
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: Clutch question
Could be a bad throw out bearing or pressure plate finger.
trailers are for boats |
#5 | |
Active Member
![]() Join Date: Jul 2007
Re: Clutch question
Also, if the clutch has been replaced, the flywheel/pressure plate may not have been resurfaced or resurfaced properly. Or as in my case, a defective clutch disk was the cause. |
Re: Clutch question
my throwout bearing makes alittle chatter. it gets wosre as you increase the pressure on it.
Re: Clutch question
Also clutch facing material can do it, I have a ceramic clutch and if you try to smoothly engage it, it will chatter. In my case it is engaged or not, so I litterally have to dump the clutch every single time, the cops love that by the way! If stocker, I'd be looking to get a new clutch pack and resurface or better yet buy a new OE replacement flywheel (about $75 from Summit) as the old one could be warped, thin, out of round, etc, etc and is probably 40 ish years old, too.
