Old 07-15-2008, 02:46 PM   #1
stingray72
Red Headed Step Child
stingray72's Avatar
Oil Pan Gasket
I swear I've been searching but..
When you guys do gaskets. what do you use? the gasket you buy at Napa etc. or the stuff that comes in a tube? Any recommendations?
Oil Pan gasket on a crate 350 btw
I hate oil leaks and i hate doing gaskets
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 07-15-2008, 03:10 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Oil Pan Gasket
I've never had good luck with gaskets from a tube. I know manufacturers use it extensively, but, I'm just not happy with results. They always seem to leak prematurely.
68gmsee is offline   Reply With Quote
Old 07-15-2008, 03:21 PM   #3
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: Oil Pan Gasket
The rubber one from Napa is the one I use... haven't had a leak yet.... (knock on wood!)
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 07-15-2008, 03:52 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Oil Pan Gasket
Fel-Pro one Piece
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 07-15-2008, 04:03 PM   #5
Sammy
Re: Oil Pan Gasket
2nd one piece gasket..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-15-2008, 06:24 PM   #6
umwtnt
umwtnt's Avatar
Re: Oil Pan Gasket
Fel-Pro one piece is the only way to go. Simple to install and prevents a lot of leaks at the ends of the gaskets. Well worth the price.
umwtnt is offline   Reply With Quote
Old 07-15-2008, 07:04 PM   #7
70rs/ss
70rs/ss's Avatar
Re: Oil Pan Gasket
Wow, I had an idea and it seems that by a semi unanimous vote it was a good one too!! One piece Fel Pros all the way, you still need a dab of ultra copper or the like in the corners, but it'll do the job!! If you can get the metal pieces that go alone the edge of the oil pan to ensure the thin pan metal doesn't warp. I do not know what you'd call them, but they look just like the pan rail and are pretty think, that is just a bit more insurance against leaks.
70rs/ss is offline   Reply With Quote
Old 07-15-2008, 09:39 PM   #8
Sport/Truck
Sierra Grande Club
Re: Oil Pan Gasket
Now you mention it......... after I have mine installed
(fingers crossed for no leaks)
s/t
Old 07-16-2008, 05:05 PM   #9
kcjones
I wish I was a cowboy
kcjones's Avatar
Re: Oil Pan Gasket
I third the rubber, well worth the expense, but I'd definitely say, ALWAYS use some gook around the corners, no matter how good the rubber/steel is at not compressing out, the corners will still seep.
In fact, I'd go so far as to say use the RTV all along the front and back parts of the pan, probably don't need it on the side rails, especially with the reinforcement rails.
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 07-16-2008, 09:13 PM   #10
cruiserman
Re: Oil Pan Gasket
Put some Hylomar between the gasket and block to make removal easier in the future.
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 07-16-2008, 09:23 PM   #11
Long Roof
Old School, New Style
Long Roof's Avatar
Re: Oil Pan Gasket
Rubber Felpro is the only gasket I will ever use again. I second the dap of sealant in the corners. My first gasket is completely dry but the one I put on the Jimmy leaks a small bit from the rear main. I did not use the sealant on either gasket.
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 07-16-2008, 09:23 PM   #12
rick0312
rick0312's Avatar
Re: Oil Pan Gasket
Fel-Pro one piece.
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 07-17-2008, 12:52 PM   #13
stingray72
stingray72's Avatar
Re: Oil Pan Gasket
Cool guys, thank for the info
as a follow up oil leak question. how tight should valve cover bolts be torqued? I know not extremely tight but mine seemed to be really loose which is why I think oil was being slung all over the place it seemed. I snugged them up with a small rachet so I should probably replace those gaskets also
-Homer Simpson
Old 07-17-2008, 03:44 PM   #14
kcjones
kcjones's Avatar
Re: Oil Pan Gasket
3 ft/lbs on valve covers, probably 5 on center bolts. Rubber gaskets you can go a little higher than with cork, but don't overtighten, you'll squish 'em out.
-Kris
Old 07-17-2008, 07:01 PM   #15
cparman
sharp as a marble
Re: Oil Pan Gasket
put a felpro one piece on my 69 today. Damn shame they don't make one for our truck in chevrolet orange!! The felpro one piece is my choice even if it is ford blue
cparman is offline   Reply With Quote
Old 07-17-2008, 10:17 PM   #16
PipsC10
PipsC10's Avatar
Re: Oil Pan Gasket
who carries the felpro one piece? I have access to NAPA and Kragen. When you guys talk about putting a little silicone on the gasket, are you talking about where the curved parts for the timing chain and rear main seal meet the flat part of the gasket? I just put a 3 piece gasket set on my motor and I KNOW it will leak as soon as I put my motor back in service.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 07-18-2008, 12:39 AM   #17
Husker
Husker's Avatar
Re: Oil Pan Gasket
Can ya get the Oil Pan off with the motor in the truck?
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 07-18-2008, 09:32 AM   #18
68gmsee
Active Member
68gmsee's Avatar
Re: Oil Pan Gasket
Ron
You have to lift the engine to remove the oil pan. Use caution...
If you need to do it, I'd suggest to get a manual and follow all of the steps to make sure you don't forget to disconect something.
Old 07-18-2008, 12:59 PM   #19
steelhorse
steelhorse's Avatar
Re: Oil Pan Gasket
I would go with the rubber also.If you have to go with any silicon type product (like intake manifolds)get some Right Stuff it is the best out there.It is made by permatex.
steelhorse is offline   Reply With Quote
