Old 07-15-2008, 04:34 PM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Electric Fans - what all do I need to buy
Next project is going to be dual electric fans.
I am looking at Spal fans (16" if they will fit)
1 - Push or pull style?
2 - Does the extra shroud to mount them in make much difference
3 - I have a stock Alternator - is it time to upgrade that if so to what
4 - Can I parallel wire the fans so the thermo switch terms them off and on @ the same time or go with the Dakota digital adjustable power source?
5 - Who makes a slick wiring harness for dual fans or should I make my own?
Any other thoughts, concerns, tips or tricks for a great fan install?
Many thanks
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 07-15-2008, 05:50 PM   #2
cparman
sharp as a marble
Re: Electric Fans - what all do I need to buy
I had a Spal 16" on my BB Chevelle. NOISY!!! and would not keep up with Florida summers. I went to a dual fan set of 11" in a spal and they were noticable quieter, and would keep my ZZ502 between 1/2 & 3/4 on the temp gauge with the air on. I know that SPAL makes a fan controller, and I have not used one of these. I hear that they are the cats meow! this controller will allow you to set on and off temps, and turn the fans on when the a/c is on. I am going thaqt route on my Sb 69 as soon as I get the 700r4 in it. Trans first, and a/c next month or so. I really liked the dual fan set I had on my Chevelle. The dual fan set will require you to make a couple of brackets, to mount them to your radiator. The fan controller will come with wire ( I think ) and you should have everything you need. FUSE PROTECT EVERY THING!! SOMKE IS BAD!!
cparman is offline   Reply With Quote
Old 07-15-2008, 06:35 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
We sell a complete kit. Fans, shroud, thermostat, wire, terminals, over-ride switch, and hardware. Comes with a wiring diagram too. They are Duel 12" not duel 16" fans though. http://www.classicheartbeat.com/radi...&__related.htm
WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-15-2008, 08:56 PM   #4
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
classic - can you send me the depth of this assembly?
ProStreet68SB is offline   Reply With Quote
