Old 07-15-2008, 06:57 PM   #1
chevymotocross
chevymotocross's Avatar
Not sure which to choose: 3/4 3/5 or 4/5
Got an 87 r10 pickup. 5 leaf spring rear. Most I haul, would be either 2 dirt bikes in the bed, or, pulling a 5x8 trailer with bikes and gear. After lowering, I would want the truck to continue doing those duties.
I don't mind c-notching, it doesn't look too hard using a rotary air cutter, or possibly a sawzall. I also don't mind notching the bed support if I were to go with the 3/4 shackle hanger setup. I am looking for either a level stance, or a slight front rake (somewhat like factory). I also want the truck to corner pretty well, and plan on adding a front stabilizer bar as well (not equipped from factory).
If I were to go 3/4, seems like most of my factory ride quality will stay the same. Shackles and hangers seem a bit more involved than a flip kit though, and if I ever wanted to go lower, I really can't with a shackle/hanger. I could with the flip.
If I do the flip kit, I may have problems with my tailpipes hitting the rear axle, so I'd have to dump the exhaust if I do it. I want to make sure the front goes with it. What I mean is, DJM sells an inexpensive 3/5 kit, but will this cause the truck to have that "boat stance" which I certainly don't want? Should I add a 1'' lowering spring to make it a 4/5 or will this not be needed?
As for the wheels, I will be running 15'' alloys, and I am aware of the issues I may have with the 3'' spindle, I hear grinding is minimal. I don't want big gaps between tire and fender, but I also don't want any rubbing. If I go 3/4, I am running 255/70/15 all around, like slonaker's truck, or stagger it with 225/70 front and 255/70 rear. If I go 3/5 or 4/5, I plan on running either 255/60/15 all around, or 255/60 up front and 275/60 rear, not sure yet. What would you guys recommend, staggered or not?. Also, will the 255/60/15 rub on a 4'' front drop?
chevymotocross is offline   Reply With Quote
Old 07-15-2008, 07:16 PM   #2
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
Re: Not sure which to choose: 3/4 3/5 or 4/5
I personally like a slight rake. I am doing a 74 right now and am planning on a flip for the rear I already put 3" drop spindles and am going to put 1" or 2" depending on how low the rear is after the flip. I was going for a slightly tucked tire look with a 245-60-15 front and a 275-60-15 rear. I'd go as low as you feel comfortable with since you know what the roads in your area are like. these trucks look better the lower they get IMO but if the roads suck in your area you might not want to drop it as much.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver
74 swb,350,350,driver & future project
"There's no such thing as a finished project"
GMBowtie79 is offline   Reply With Quote
Old 07-15-2008, 08:40 PM   #3
ton*loc
ton*loc's Avatar
i was wondering all the same things. i still like to use my truck for normal truck duties. but i like the look of lowering them
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 07-15-2008, 09:32 PM   #4
f.monroe
f.monroe's Avatar
I went 2.5/4 using spindles and replacement rear leaf springs . It rides nice and is a total bolt on . The front is probably a little lower since I am using the original coils which I am sure have settled a little over the years . I like the stance of my truck . Top pic is stock and bottom pic is lowered .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-15-2008, 11:31 PM   #5
chevymotocross
Well, the roads here in Connecticut, especially in my area, are pretty horrible. New England winters and plow trucks make it really bad, they are actually rated one of the worst states in the country for road conditions (not suprising). f.monroe, for a mild drop, that 2.5/4 kit really brought it down nicely. That's a perfect stance even though you are running what appear to be 17's.
Old 07-15-2008, 11:38 PM   #6
f.monroe
f.monroe's Avatar
18x8 front and 18x10 rear with 255/55/18 front and 275/60/18 rear .
Frank
Old 07-16-2008, 12:10 AM   #7
andresco50
andresco50's Avatar
I would choose a 3/4 drop if you want go low with the bikes... I have a 2" rear drop in my 2001 when I go to the track with my bike it drops 1/2" so you can go with 3/4 without problems
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 07-16-2008, 07:22 AM   #8
AceX
>130dB Moderator
AceX's Avatar
The 2/4 drop will be perfect for what you need. If you want to go lower later on, it's not a big issue.
My truck sports a 2/4 drop via spindles, shackles, and hangers. Wheels are 15x10.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 07-16-2008, 12:52 PM   #9
chevymotocross
wow, these shackle/hanger drops bring the truck lower than I thought they would. Acex, that is a perfect stance and it looks like you are even running a 60 series tire. I thought there would be more gap but that is perfect. Maybe I won't have to run 70 series tires. I really like the stance yours and f.monroe have. I think a flip kit may be too low for what I'm looking for, and then, I'd have to add front coil springs to even out the front, which then screws up alignment and ride quality. Atleast with the shackle/hanger kit, I won't have to alter the frame. I was planning on the DJM 3'' front spindle, but your 2.5'' spindles give it plenty of rake, plus I wouldn't have to do any grinding. I think I will have to look further into those 2.5 spindles.
Old 07-16-2008, 03:17 PM   #10
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Here's mine when I was running a 3/5 drop with 17's...
CLASSIC87' is offline   Reply With Quote
Old 07-16-2008, 06:20 PM   #11
chevymotocross
Wow, yours looks awesome too classic87. Your's has a nice front rake to it. The 3/5 seems iffy. Yours looks awesome. Another member here, I think 454HO, did a 3/5 as well but his does not seem to have the slight front end rake, his seems to have a bit more gap at the front wheels.
Old 07-16-2008, 06:41 PM   #12
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Oh crap ^^ ... that's a 5/6 drop... I had 3" spindle on my mind and I forgot to add cutting the coil which gave another 2". Sorry about that...
Anthony
Old 07-16-2008, 07:45 PM   #13
spr85gmc
spr85gmc's Avatar
do you have to notch the frame for more than 5 in' in the reae?
spr85gmc is offline   Reply With Quote
Old 07-16-2008, 08:07 PM   #14
Eighty-6
Hi,
I'm new to the forum and have been picking up alot of good ideas for my truck. See pics
I'm also trying to figure out which drop to go with. One quick question if you run bigger wheels would you need more of a drop to compensate for the larger rims to basicly keep the same height.
i.e. let say your running 18's on a 2/4 drop and you move to 20's would you need to move to a 4/6 drop to stay at the same height.
Eighty-6 is offline   Reply With Quote
Old 07-16-2008, 08:55 PM   #15
spr85gmc
spr85gmc's Avatar
^ most of the time yes but it depends on what tire size you had before compared to the new ones. some one else should shim in with more info soon.
Old 07-17-2008, 03:12 AM   #16
AceX
>130dB Moderator
AceX's Avatar
Glad you like it.
Tires are both 60 series. 255/60/15 up front and 275/60/15 out back.
If you do the flip kit, plan on adding helper bags out back to help out when towing. Even though it's not a real heavy load, you'll want to set it up so you can tow a larger load if you have to.
Living Life @ 130dB
RIP El Jay
Old 07-17-2008, 01:28 PM   #17
Malo83
Cruzzzn' Vet
Malo83's Avatar
This is my 83 with a 4/5 drop
Malo83 is offline   Reply With Quote
Old 07-17-2008, 03:29 PM   #18
GMBowtie79
GMBowtie79's Avatar
Originally Posted by Eighty-6 View Post
Hi,
First off . What worked for me was I lowered mine first with the 15" ralleys and then went to a larger wheel. The over all tire size is the determining factor.(i.e. A 235-70-15 is about 28" tall. A 245-40-20 is about 28" tall also.) So if you plan it right your drop will stay relitivly the same with the larger rims. On mine I used the tires to get the rake that I wanted.
Old 07-18-2008, 05:43 PM   #19
Eighty-6
Thanks for the info guys.
Old 07-18-2008, 06:10 PM   #20
flamingbig10
6.0 powered square
flamingbig10's Avatar
well mines susposed to be a 5/6, but it looks like a 4-7 don't know how that happened, in front theres djm 3inch drop spindles and 2inch coils in back with a beltec flip kit and 3 remaining leafs out of the 6 and the wheels are cragar street stars 15x7s 4.125 in. Backspace in front with a 215/70 tire and back 15x8 4.125 in. Backspace with a 275/ 60
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-10-2009, 05:03 PM   #21
3r!c84
Badass
3r!c84's Avatar
any one got any pics close-up with the lowering shackles and hangers?
3r!c84 is offline   Reply With Quote
Old 04-10-2009, 05:18 PM   #22
Dapper Dan
Dapper Dan's Avatar
Frank
Frank where did you get your leaf springs from?
Dapper Dan is offline   Reply With Quote
Old 04-10-2009, 06:10 PM   #23
JohnC
JohnC's Avatar
Frank every time I see that truck I drool. That is just a sweet looking truck. Your black one is too. I'm really jealous.
JohnC is offline   Reply With Quote
Old 04-10-2009, 09:37 PM   #24
3r!c84
Badass
3r!c84's Avatar
Frank
did u have to cut into the bed supports?
Old 04-11-2009, 07:55 AM   #25
JohnC
JohnC's Avatar
I don't think Frank cut anything on his setup. That is the main reason he went the way he did. That way it could be unbolted, and you would never know.
