Old 07-15-2008, 07:14 PM   #1
chevymanjt
chevymanjt's Avatar
chop top
hey has anyone ever choped a top yourself? if so, what kind of a process is it? thanks.
chevymanjt is offline   Reply With Quote
Old 07-15-2008, 09:32 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: chop top
4" chop top....http://community.webshots.com/user/hotrodhorn get yourself a copy of How To Chop Tops, written by Tex Smith. there is a lot of info, as well as several methods on chopping the 67-72, cutting glass, garnish mold ect. I am NOT a body man, just a backyard "buck", that can weld fairly decent, & have a little "tenacity" for what I like. Plan it outwell, start to finish, measure 3 times & cut once. best of luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-15-2008, 10:39 PM   #3
chevymanjt
chevymanjt's Avatar
Re: chop top
thanks man, i work in a body shop but its on m1 army tanks so im not used to welding on thin metal. maybe with some good info i can handle it. thanks again.
