07-15-2008, 07:43 PM | #1 |
Passenger side alternator pics
I have a pass. mount alternator braket and alternator and I can't remember where it mounts, I have the little L beaket for the bottom of the alternator and I don't know where that bolts to either. If some could get me some picks of their pass. mounted alternator that would be great.
I guess I should've payed more attention when I took it apart. Thanks in advance.
1967 c-10 longbox project, check it out in projects 1969 c-10 parts pickup, twisted frame Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block |
07-15-2008, 08:48 PM | #2 |
Re: Passenger side alternator pics
ttt
07-15-2008, 08:51 PM | #3 |
Don't have a pic, but surely someone will. The 2 holes on the L bracket mount to the water pump. Then the long bolt goes through the top hole of the L bracket, through the alt., then the spacer, then screws into the head. Then the long adjuster just goes to top mount on the water pump. Same thing for the new style except one also goes to the water neck.
07-15-2008, 09:10 PM | #4 |
here you go...went out in the backyard and took these for you...hope that helps.
07-16-2008, 07:11 PM | #5 |
that is exacly what I was looking for, thanks alot
07-16-2008, 07:30 PM | #6 |
glad to help.
07-16-2008, 07:45 PM | #7 |
is that a special water pump or is it just a regular ol' water pump
07-16-2008, 08:02 PM | #8 | |
member #16
Its just a regular ol' long water pump.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
07-17-2008, 09:08 AM | #9 |
ok that is what I figured
thanks
