07-15-2008, 09:14 PM | #1 |
i need help asap! help me!
ok i got a 69 short step and the shifter i had on it worked fine but when ever i put it in reverse it wouldnt reverse! drive, park, neutral worked fine! so i got a new shifter and installed it corectly so i tried it and everything works except reverse again, why is that?
07-15-2008, 09:17 PM | #2 |
72 Chevelle Club
Re: i need help asap! help me!
I would say reverse is out of your tranny .
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
07-15-2008, 09:19 PM | #3 |
huh?
07-15-2008, 10:36 PM | #4 |
The oddest Todd around
In an auto tranny, reverse is the first to go (break). Reverse uses more pressure than the other gears.
Most likely your tranny needs to be rebuilt or replaced. Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? Last edited by toddtheodd; 07-15-2008 at 10:37 PM. |
07-15-2008, 11:07 PM | #5 |
rebuilt, damit!
07-15-2008, 11:07 PM | #6 |
72 Chevelle Club
YUP !! What you said !!!
07-15-2008, 11:31 PM | #7 |
its all about the +6 inches
have you checked the trans fluid level with the engine running on level ground?
07-15-2008, 11:40 PM | #8 |
I blew a 2004R once... In park, it felt like the car was wanting to move. In Reverse, it was in park, In Neutral, it would drive forward, in Drive, it was like it was in first... which was the same as when it was in 2 and 1...
Let's just say that "I" may have caused the problems with the transmission... but hey... I was only 16 at the time. I went through 4 transmissions in 1 year.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
07-16-2008, 01:32 PM | #9 |
the trans fluid hasnt been changd in like 2 yrs so i think thats probly the problem?
i checked the fluid this morning with the truck runing and it kinda showed that there was nothing in there! what do u think? |
07-16-2008, 01:36 PM | #10 |
Adding tranny fluid won't hurt anything
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
07-16-2008, 01:39 PM | #11 |
im gonna put some fluid in and ill let u guys know what happens!
what kind of fluid should i get? |
07-16-2008, 01:42 PM | #12 |
regular ATF fluid. I would recommend putting something for the higher mileage transmissions, but that's just me.
By the way, if you decide to pull the pan, make sure you go ahead and change the filter and gasket.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 07-16-2008 at 01:43 PM. |
07-16-2008, 01:46 PM | #13 | |
Shawn And BTW, please quit using ASAP in the title of so many of your posts. If you have a true emergency that is one thing, but to use it repeatedly.... well you know the story of the boy who cried wolf... Just a friendly word of advice. Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 07-16-2008 at 01:50 PM. |
07-16-2008, 06:03 PM | #14 |
no need to check the fluid in neutral, park is fine
2 years on tranny fluid is not bad. Probably not even needed to chainge, but it probably wouldn't hurt. Running it that low WILL damage it Any dextron 2 or 3 will be fine in your tranny. |
07-16-2008, 10:29 PM | #15 |
Yeah, What's the text book process for this - 1. Warm tranny, 2. On level ground run it through the gearz with foot on brake. 3. Put back in park and check fluid. 4. Add if needed (Do Not Overfill).
07-16-2008, 11:16 PM | #16 |
yep, stick with that
I would get it on the stick before driving it again though. If you get it just below the add mark, then drive it around the block, then you can check it and top it off. |
07-16-2008, 11:29 PM | #17 |
Loss of reverse could definitely be caused by low fluid. Let us know if that solves the problem.
Hopefully if it was low, you haven't burned up the transmission. Todd
07-16-2008, 11:46 PM | #18 |
i got a new filter and gasket for my tranny, when i take the fluid pan from underneath the tranny do i have to take the shifter lickage too?
cuz its connected to it rite, im sure i do! |
07-17-2008, 12:01 AM | #19 |
nope, linkages are left alone.
Depending on what you have for tools, and how your mount is, sometimes you'll have to remove the bolts from the crossmember to tranny mount, and raise the trans just a bit to get the rear most bolts. |
