Old 11-11-2002, 11:48 PM   #1
polevault1977
Pick'n up the pieces!
polevault1977's Avatar
Question Motor mount question
Hi All, I'm new to the forum and rebuilding these great (67-72) trucks. I've learned a lot of info from the forum. Best resource I've found!
My question, I bought a bunch of chevy truck parts. One wrecked truck and another 71 frame and a couple of beds. No motor or tranny in any of them. I have stripped and sandblasted the 71 frame. It's now painted and I've basically got the frontend rebuilt. What I cannot figure out is the motor mounts. I have two sets. One is cracked and probably no good. They line up with the front set of holes. The other set is in great shape (cleaned and painted) and they line up with the back set of holes. I am planning on running a sb. Will the set that goes in the back work with a sb or they for 6 banger? Any help appreciated. I'll try to attach a pic. Never did this before.
Danny
polevault1977 is offline   Reply With Quote
Old 11-11-2002, 11:51 PM   #2
frost89434
frost89434's Avatar
The back set of holes are for a 6 cylinder. But you can put a small block there. That is where I have mine. And it worked fine.
Jim
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 11-11-2002, 11:59 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
welcome to forum
6 cyl brackets are taller longer than SBC ones, i canmt tell which you have in pic, its hard to tell but whichever are shorter are the SBC ones and whichever are longer are the 250/292 ones
292 have an exception though, the pass side bracket on 292 are in forward holes same as V-8 uses and is not same bracket as any other engine size, i dont have digicam to show you difference but i have a couple of 292 pass side brackets here, and driver side one for both 6 cyl engines are same one and both use rear holes unlike SBC
Fast68Chevy is offline   Reply With Quote
Old 11-12-2002, 12:03 AM   #4
sub4rvr
sub4rvr's Avatar
small block.
72 C10 Suburban
90 S10
57 F100 (2)
67 Mustang (2)
69 Torino GT
00 Mustang GT Conv.
sub4rvr is offline   Reply With Quote
Old 11-12-2002, 12:05 AM   #5
polevault1977
Thanks for the quick replies. I'm still not sure which mount is in the pic above. Any measurements I can take or a different pic that would help in IDing this mount?
danny
Old 11-12-2002, 12:09 AM   #6
sub4rvr
sub4rvr's Avatar
sorry, i don't know the differences, but that's where a 350 bolts up. i can measure mine if you need me to. Randy can be of more help though.
72 C10 Suburban
90 S10
57 F100 (2)
67 Mustang (2)
69 Torino GT
00 Mustang GT Conv.
Old 11-12-2002, 12:13 AM   #7
polevault1977
Randy, thanks for hanging with me. I just shot of couple of more pics. Hope these show them a little better. They are not bolted in. Danny
Old 11-12-2002, 12:17 AM   #8
polevault1977
pic
Old 11-12-2002, 12:21 AM   #9
polevault1977
another pic, they didn't turn out very good though
Old 11-12-2002, 12:46 AM   #10
Hutch
Hutch's Avatar
Those exhaust holes through the crossmember look a lot like the ECE Rodstoration.
Must be planning on droping that Truck.
From what I have gathered the front mounting holes (forward)are for the small block and the rear are for the inline 6 but you can mount a sb in the 6 cyl position.
Quite a few members have done this(v8 in the 6 position) with good results.
The problems that they encounter are clearance for the distributor and distance to the fan shroud (depending on the Water pump)
A basic rule as to factory location is v/8 forward 6 to the rear.
As to your question about the engine mounts.Whether they are for a six or eight I will leave it to the experts as all of mine are V/8's.
I hope this helps
As alway's feel free to correct me if I am wrong on this line of thought.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 11-12-2002, 12:56 AM   #11
Fast68Chevy
all correct cept for that 292 is oddball and pass side is forward and driver side is rearward and pass side 292 uses special tree bracket
Old 11-12-2002, 01:25 AM   #12
crazy longhorn
Fabricate till you "puke"
You have the 6 /250 stands shown in the pics. as already posted, your smallblock will mount on them, but will sit roughly 3 1/2" back from the V8 (factory)position. My longhorn is set up this way to slide a little weight rearward. I run an HEI dist, but clearance is pretty tight......I opted to drill the hole in the stand to 5/8"(the ones for the motor mount bolts), to give a little room to "cheat" a fraction of an inch. the holes in my trans crossmember are also slotted. for correct lenght on the pump/shroud, I run a 73 up long pump,pulleys, brackets, steering pump. Good luck
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-12-2002, 08:32 PM   #13
polevault1977
Thanks all for the info. Where else could you go and get such good feedback?!!!! I've already hit the local junk yard and found a good set of v-8 motor mount brackets. Anybody need the other one I have for the 6?
Hutch, you are right on with the exhaust. I figure with 6 inches of drop I'll need to route it through the crossmember,
Crazy Longhorn, thanks for the id. All have been very helpful.
Until the next question,
Danny Frazier
Old 11-12-2002, 08:37 PM   #14
crazy longhorn
Happy 'truckin dude!
