Replace these yet? (brake pedal bushings)
I've checked the dealer, NAPA, GMC Paul and LMC with no luck. LMC shows the ones for the clutch pedal that rides inside the brake pedal shaft but they are smaller. These ones are for the brake pedal and are between the brake pedal shaft and the shaft it rotates on that attaches it to the bracket. Brake pedal rotates on the outside of the shaft and the clutch rotates on the inside... do I have this right. My truck is a 72 auto.
Re: Replace these yet? (brake pedal bushings)
Give one of the board vendors a call. I am not sure if these are repoped, but they (board vendors) will.
Arrived on a Pale Horse
If you can't find a re-pop, I probably have one laying around on a spare brake/clutch setup. My trucks are both auto, and I got a couple brake/clutch setups with some other parts I acquired over the years. I'll check tonight.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
