Old 07-16-2008, 07:30 AM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
LS1 fans on a BB radiator
Is anyone running LS1 electric fans? How well does the shroud fit? How about LS1 fans on a 454 radiator?
I'm ready to ditch my current dual 14" fans. I need somewthing with a shroud. I could probably make my own shroud. However, I need special tools to bend aluminum metal sheets. I found some LS1 fans on craigslist for $40. I hope they are avaiable. I have another 1100 mile trip next week to challenge the ZZ4.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-16-2008, 07:44 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: LS1 fans on a BB radiator
Good Luck
However, if you find that to be a problem, look at the dual electric fans that SPAL sells with their own shroud assemblies. Easy to mount and work great. I have two sets on my different trucks and have not had an overheating problem yet. Summit sells these under the "Be Cool" name. Dual 11" electric fan setup.
piecesparts is offline   Reply With Quote
Old 07-16-2008, 02:10 PM   #3
pcmcobra
pcmcobra's Avatar
I run ls1 fans on my stock radiator. I have a post with pics somewhere on this board.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 07-16-2008, 09:39 PM   #4
gchemist
gchemist's Avatar
Well, looks like BADBOW is going to get some LS1 fans!! My A/C blew a big cloud of R-134 yesterday. I turned off the A/C and took my Jimmy to work. I drove over to my A/C guytoday. He connects the gauges and pressure was good. We found oil over part of the engine and lines. The pressure switch behind the compressor did its job. I was dreading the worst. Replacing the new lines again. We found the lower fan was not running.
I found a set of LS1 fans on Craigslist for $40!! I'm meeting the guy at 6:45 AM to buy them. I'll spend most of the day install in them. I hope I don't need to drain the coolant. I'll snap a few pictures. I was thinking of upgrading my Jimmy to LS1 fans. Now BADBOW get's them first.
pcmcobra,
How old is the thread? Did you post the main topic?
Old 07-16-2008, 09:46 PM   #5
gchemist
gchemist's Avatar
Found the thread!!
http://67-72chevytrucks.com/vboard/s...d.php?t=254187
Old 07-17-2008, 01:00 PM   #6
Pyrotechnic
Pyrotechnic's Avatar
I have some on my 77. All you need is a few custom brackets. I made some that let the fans sit in the lower shroud clips and bolt to the upper radiator support just like the stock shroud does. I also found a place on evilbay selling the correct weather pack pigtails to wire these in.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 07-18-2008, 09:55 AM   #7
blazer2007
what are LS1 fans from?
blazer2007 is offline   Reply With Quote
Old 07-18-2008, 05:01 PM   #8
gchemist
gchemist's Avatar
98-02 Camaros and Corvettes. At full power, they move a lot of air!
