Old 07-16-2008, 02:35 PM   #1
JDahl
What size tires and wheels work best w/ 4in lift
I lifted my blazer 4in with new springs all around. But now, the old 31/10.50's just are not looking right. What combination of tires can I use with out having to cut the fenders. I have been toying around with 16's but I am not sure what size tire I could use. What sizes have you guys used?
JDahl is offline   Reply With Quote
Old 07-16-2008, 03:42 PM   #2
70rs/ss
70rs/ss's Avatar
Re: What size tires and wheels work best w/ 4in lift
The wheel size doesn't eefect the fitment as far as fender clearance, so I'd say a 33" tall will fit for sure and 35" tall tire might work if you don't wheel it extreme with a lot of suspension articulation or you might rub, but I am sure some of the experienced wheelers here will chime in and offer experienced suggestions. BTW 16" rubber is getting to be more common so wheels and tires should be reasonable, but 17, 18, 19" stuff gets spendy, just an FYI.
70rs/ss is offline   Reply With Quote
Old 07-16-2008, 03:53 PM   #3
Big J
Its lookin' like a Blazer!
Big J's Avatar
33 0r 35 12.50 tires should fit fine, depending on the intended use. Backspacing would come into play with the 35. You'd need to stay around the same as a stock ralley, maybe a little wider wheel. I don't have the body on yet but you can see my 35's on the stock ralleys in my build thread. Click the link below. Pics are a few pages back.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 07-16-2008, 04:04 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
What's your intended use of the K5?
I temporarily have a set of 35"s on my 70 K5 with 4" lift springs and it is not a good fit on that vehicle but I had these same tires on a 69 K20 with a 4" lift and never had any rubbing just driving on the road - off road would have been a bit of rubbing I'm sure if it was crossed up. The 4" lifts were different brands and I'm guessing the K5's 4" lift isn't giving me an actual 4" lift.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-16-2008, 04:04 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
IMO - stock tires look great with a 4" lift...
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-16-2008, 04:30 PM   #6
Jtrux
I'm a poor spectator
Jtrux's Avatar
Yep, looks good.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 07-16-2008, 05:25 PM   #7
JDahl
I wish mine looked that good, what size of tires/rims are you running?
Old 07-16-2008, 05:34 PM   #8
bouncytruck
SKINNY TIRES RULE!
P235/85R16's on the stock 16" rims (yup, stock 16's).
bouncytruck 1972 K5
Old 07-16-2008, 08:52 PM   #9
BLUE THUNDER
BLUE THUNDER's Avatar
I'd go with at least 33/12.50/15. 35 at the biggest. Later, Mario
BLUE THUNDER is offline   Reply With Quote
Old 07-16-2008, 09:44 PM   #10
Big Block
Big Block
Big Block's Avatar
4" lift 33x12.50x 15" tires 10"rims. Rims soon to be replaced.
Big Block is offline   Reply With Quote
Old 07-17-2008, 06:36 AM   #11
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Just my opinion, but this combo is a perfect fit.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
