Old 07-16-2008, 10:45 PM   #1
GMC65Guy
3 on the tree dipstick??
Do the 3 on the trees come with dipsticks??? I either don't have one or its extremely hidden.
GMC65Guy is offline   Reply With Quote
Old 07-16-2008, 11:14 PM   #2
blackedoutharley
Re: 3 on the tree dipstick??
No, the manual transmissions have a fill plug on the side that you remove to check the fluid level.. Take the plug out (with truck on level ground) and stick your pinky in.. when you remove said pinky there should be oil on it and that is considered full.
blackedoutharley is offline   Reply With Quote
Old 07-16-2008, 11:21 PM   #3
71swb4x4
71swb4x4's Avatar
Don't get your pinky stuck!! I use a piece of wire. Better yet, if you aren't sure of the age of the oil drain it all and replace with new.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-16-2008, 11:51 PM   #4
greg64
greg64's Avatar
I'd second the drain and fill idea. It'll show you where the fill and drain plugs are, which means you'll both know that the right amount of lube is present, and that the lube is fresh.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
