Old 07-17-2008, 01:28 AM   #1
Kim57
Kim57's Avatar
Need Some Opinions
I need to make the roll pan for the bed that I built and need some opinions on what you guys think will look the best.
When I build it I plan on welding to the bed and not having a seam where it buts. Thanks for any input you have on this.
Kim
Kim57 is offline   Reply With Quote
Old 07-17-2008, 08:26 AM   #2
weldvair@embarqmail.
Re: Need Some Opinions
I'll vote for it bending verticle.....Don
weldvair@embarqmail. is offline   Reply With Quote
Old 07-17-2008, 10:05 AM   #3
CAL 58 GMC
CAL 58 GMC's Avatar
How about a fill panel from the bottom of the fenders following the contour of the fender under the bed.
CAL 58 GMC is offline   Reply With Quote
Old 07-17-2008, 10:18 AM   #4
Kim57
Kim57's Avatar
I was thinking that same thing but don't know how to make the curve and keep the round corner of the bed. I may have to experiment and see what I can come up with.
I added a couple pics of what I think you mean Cal.
Kim
Old 07-17-2008, 12:46 PM   #5
mylow53
mylow53's Avatar
cut some exaust pipe to get your curve...
curve is the best choice since your dominate object is rounded you need to complement it not compete with it
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 07-17-2008, 03:27 PM   #6
Kim57
Kim57's Avatar
I think I've come up with a solution to my problem on it. I'm having some 1" tube bent to match the contour of the rear fender and then I will have to weld some 16 gauge sheet in-between to make the roll pan. This should keep my rounded corners and help everything to flow nicely.
Kim
Old 07-17-2008, 04:42 PM   #7
BlueJeep
BlueJeep's Avatar
What's the radius at the back corners of your bed? Just looking at the pictures, I'd think 1" tubing is too small and you'd need something like 1.5" or 1.75" -- keeping in mind I'm just looking at the pictures.
1" tubing will only give you 1/2" radius if you weld the sheetmetal at the tangents of the tube to form your 90 degree angle (hope that makes sense).
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 07-17-2008, 07:37 PM   #8
Kim57
Kim57's Avatar
Its 1". I took a piece of the leftover corner from the bed to my steel guy and 1" will work just fine.
Thanks for the concern though.
Kim
