07-17-2008, 08:31 AM | #1 |
My Camaro Headers Install pictures
Headers seem to be about the most asked about question on this board. I just installed a set of Headman Elite full length Camaro Headers on my lowered 1976 C-10. The Camaro headers fit 1967-1981, here are some photos so you can see the clearance. The passanger side went in easy from the top, the drivers side I had to go from under neath. I still need to hook it up to my new exhaust H pipe.
1976 C-10 shortbed 2wd (work in progress) Mods: Stock 307, 700R4 Transmission, Hurst Pro-Matic shifter, 2100 rpm stall converter, Headman Elite 1 5/8" headers, H-pipe, 2 1/2 exhaust through Magnaflow mufflers, 3.73 Motive gears, superior axels and Eaton Posi carrier http://www.cardomain.com/ride/3136537 Last edited by gearhead1968; 07-17-2008 at 09:26 AM. |
07-18-2008, 11:52 AM | #2 |
Re: My Camaro Headers Install pictures
How are the '82-'87 different? I have an '87 and want to put headers on it. Someday it will be bagged and I don't want them to drag.
07-18-2008, 12:24 PM | #3 |
Right turn Clyde
67-81 is the year app for the camaro headers
07-18-2008, 01:27 PM | #4 |
Arrived on a Pale Horse
will this setup work on a 72 as well?
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
07-18-2008, 04:53 PM | #5 |
im curious to know whats the difference between getting headers specifically made for the truck as oppose to getting camaro headers. Is it a cost thing?
07-18-2008, 05:00 PM | #6 |
BAD BOW-Silverado XST
Car headers do cost less. However, fitting for lower trucks is ideal. 3/4 length and some full length headers don't drop below the frame rails. Exhaust is nicely tucked up.
07-18-2008, 05:00 PM | #7 |
09-14-2008, 03:11 PM | #8 |
Wow, these do have a lot less hang than the truck headers. Just one question for those running these headers. Have you had to buy a heat shield for the starter or do they hold up pretty well with the headers being that much closer?
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
09-14-2008, 08:52 PM | #9 |
It'd be alot cooler if you did
I don't understand why you used a camaro application for full legth headers. Every company makes full length headers for our trucks... its the 3/4 length ones that are harder to come by.
09-14-2008, 09:04 PM | #10 |
Because the full length truck headers hang down way to low and since my truck is lowered the truck headers are very close to the ground.
1976 C-10 shortbed 2wd (work in progress) Mods: Stock 307, 700R4 Transmission, Hurst Pro-Matic shifter, 2100 rpm stall converter, Headman Elite 1 5/8" headers, H-pipe, 2 1/2 exhaust through Magnaflow mufflers, 3.73 Motive gears, superior axels and Eaton Posi carrier http://www.cardomain.com/ride/3136537 |
09-14-2008, 11:29 PM | #11 |
Hey nice headers, they're powder coated???
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
09-15-2008, 08:09 AM | #12 |
Thanks! Headman calls it thermal coating, I guess it is very similar.
