Old 07-17-2008, 12:24 PM   #1
ont_guy_38
ont_guy_38's Avatar
72 Nova headers on truck
I run across an awesome deal on a set of headers for a 72 Nova.I did a search but nothing really came up ....gotta be somebody here has tried a set on a C10.If so could you post your results...thanks in advance
ont_guy_38 is offline   Reply With Quote
Old 07-17-2008, 01:35 PM   #2
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: 72 Nova headers on truck
68-72 or 74 nova have the same sub frame as the 67-69 camaro i believe, so they should work.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 07-17-2008, 02:11 PM   #3
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
Morning, Yes the subframes are interchangeable. I have a set of headers for the first gen Camaro (full length) and I looked at them & compared them to the set of headers I removed from my truck and the big difference seemed to be that the Camaro headers did not have as much distance (vertical) from the exhaust port flanges to the bottom primary pipes where they make the turn to the back, compared to the correct truck headers. Now I'm talking a set that came off my '77 I have no idea how far down the 67-72 needs to be. With all that said they might have fit... but they would of been very close to the floor board firewall area. You would really need to do a trial fit to make sure, or wait for a positive confirmation from someone else who has done it successfully.
God Bless, Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 07-17-2008, 03:13 PM   #4
ont_guy_38
ont_guy_38's Avatar
thats what i,m wondering ...how close to the floor would they be
Old 07-17-2008, 03:15 PM   #5
gearhead1968
gearhead1968's Avatar
God Bless, Terry
You are correct, here is my install with Camaro headers, which is the same part number as the Nova headers:http://67-72chevytrucks.com/vboard/s...d.php?t=299659
1976 C-10 shortbed 2wd (work in progress)
Mods:
Stock 307, 700R4 Transmission, Hurst Pro-Matic shifter, 2100 rpm stall converter, Headman Elite 1 5/8" headers, H-pipe, 2 1/2 exhaust through Magnaflow mufflers, 3.73 Motive gears, superior axels and Eaton Posi carrier
http://www.cardomain.com/ride/3136537
gearhead1968 is offline   Reply With Quote
Old 07-17-2008, 03:17 PM   #6
gearhead1968
Mods:
Old 07-17-2008, 03:23 PM   #7
ont_guy_38
ont_guy_38's Avatar
they look like they fit not bad gear head
Old 07-17-2008, 03:37 PM   #8
gearhead1968
I tried the correct ruck headers, but they hung down way to low, so I thought that I would give the Camaro headers a try and I am happy with the fit. It is really close to the frame on the passanger side and close to the lower control arm on the drivers side but it works and they don't hang down to the ground.
Mods:
Old 07-17-2008, 10:37 PM   #9
COMP
Originally Posted by gearhead1968 View Post
red X ,, ????
COMP is offline   Reply With Quote
