Old 07-18-2008, 06:54 AM   #1
chevymotocross
chevymotocross's Avatar
Are the factory sway bars bolt on?
I have the opportunity to purchase a sway bar setup from an 86 c10. I have to take it off myself and wanted to know if all I needed were some basic sockets and a good ratchet? Everything is just bolted, correct?
chevymotocross is offline   Reply With Quote
Old 07-18-2008, 07:10 AM   #2
Turbo85GMC
Turbo85GMC's Avatar
Re: Are the factory sway bars bolt on?
The sway bar bushings (4 of them) do all bolt on. However, the two inner bushings bolt to brackets which are riveted to the frame. You can buy new brackets and bolt them to your truck, but that's extra money if you can get the originals off the donor truck. I've heard that a good cold chisel will work if you don't have a grider or air chisel.
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 07-18-2008, 08:55 AM   #3
LEEVON
Moderator
LEEVON's Avatar
I was able to talk the yard into torching the inner brackets off sections of the frame. Got the whole set-up for $40, new poly bushings $20, grade 8 hardware $5. From there it bolts right in, the holes are already on your control arms and frame.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 07-18-2008, 09:26 AM   #4
BowTieOgre
Is your truck lowered? If so you dont really need the front brackets that are riveted on. Just drill some holes in the bottom of your frame horns and gain the extra clearance. See my pic in THIS thread.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 07-18-2008, 06:55 PM   #5
chevymotocross
I plan on lowering it 2.5'' in the front in the near future. It is stock height now.
