Need a wheel/tire recommendation
Guys, I'm just starting a little 67 drag truck project and could use a wheel and tire recommendation. The truck will be strip only and all the weight possible cut out. A 496 13-1 small solid cam motor and TH400 w/4500 stall converter will power it. The rear is a stock width 12 bolt and it will have fleet bed sides with no floor and tubs added. I was thinking about a 10" wheel but don't know what backspacing to get or if a 12" would fit inside the fenders. Does a 30x10.5 tire sound about right? thanks, bighead
#2 | |
Re: Need a wheel/tire recommendation
That tire sounds about right. I think (don't take this as the gospel) a ten inch wheel with 5 inches of back spacing will work. You might check out the centerline telstars. They look pretty sweet for the price. I had them on my old 71 truck.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
If it's tubbed you can run a 10" with 5 or even 5.5" backspacing, or a 12" with 7.5" backspace, both available in a Weld Draglite, they also make a 15x5 and 15x6" front rim to match in a 5x5 bolt pattern. That's what I have run on my 71 before with 29x14.5" tire, the 67 rear is a bit narrower but you'll still have lots of room.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 07-18-2008 at 11:06 AM. |
Thanks 71. Jeg's had some Draglite 12's with blems for $176 so they are on their way to my house. What front runner tire would you suggest for the 5" fronts? bighead
In a bias ply or a radial? I use M/T's 28x7.5" Sportsmans with a 31x16.5" back tire. What brand and size are the blems on then back, I would try to match them.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
Sorry I wasn't clear. The wheels are blems at a discouted price. I'm going to use Hoosier's around a 30x10.5 or 11.5. I was just wondering what size frontrunner is right for a 5" Draglite on on of these trucks. Thanks for your help. bighead
![]() Join Date: Mar 2008
I run a 12" wheel with a 14" tire with stock framerails .
NHRA Super Street 469C It only runs 10.90 at 156 mph I was Dragtruck when Dragtruck wasn't Cool! |
I'd go with the M/T fronts in a 28 tall. I don't recall Hoosier making a front that tall for a 5" rim, I ran Hoosiers before and had to go with Mickey fronts.
#9 | |
Do you ever run any .4 pro tree stuff? What kind of lights do have with a tire that tall?
We run a sportsman tree, so not sure, they messure 28" on a 4" rim I run them on a 6" so they're a bit shorter then that. I've always ran a taller tire so I'm use to them, I had 26" once (ended up closer to 25") put them on thought they looked way too small and took them off and returned them.
I run a 28x4.5x15 Hoosier front .
How wide are your front rims? I wondered about those but my rims are 6", but I might go to a 5" some day and a true drag front.
#13 | |
![]() Join Date: Jul 2007
He would NOT separate them even when I waved the money at him.: > ( At one time I had considered using Centerline wheels which come in a light weight version that are only 3.5" wide. Still looking .... another swap meet 1st weekend of August.
John aka "Milner" PA-IndianRider - Pittsburgh, PA 70 Chevy C10 Stepside "Gasser/Altered Drag Race Hot Rod" Where were You in '62 ? Last edited by PA-IndianRider; 07-24-2008 at 10:37 PM. |
#14 |
My wheels are 3.5's . I have the 4.75 bolt pattern . I have Strange brakes now but when I put the truck back together 9 years ago I didn't want to be stuck with the wider wheels so I had a machine shop drill my stock stuff for that bolt pattern . You can do it just like the multi pattern wheels . Just drill them inbetween the old holes .
#15 |
Ya was thinking of doing that if ever need be, I ordered my axles drilled with 2 patterns incase I ever need to buy new rims and can't find what I want in a 5x5 pattern. Do you have any pics of the 3.5's so i can see how it looks that narrow?
#16 |
All I have are my pics on my link .
#17 | |
I have been looking since last Summer for a GOOD deal on a pair of "narrow" Weld wheels for the front of our C10.... no luck so far.
John aka "Milner" PA-IndianRider - Pittsburgh, PA 70 Chevy C10 Stepside "Gasser/Altered Drag Race Hot Rod" Where were You in '62 ? |
#18 |
![]() Join Date: Jul 2008
they don't make them in 5x5 when I was looking,thats why I got the AR 6'' on the front and 10'' on the back,but I still don't understand the 12'' rim with a 10.5 tire Bighead most don't recomend a smaller tire on a wider rim
Built chevy tuff! ![]() |
#19 |
Should have read 10 1/2W or maybe a 12.
#20 |
10'' rim 5'' back 30/10.5/15 slick 12bolt stock length rearend
#21 |
Rod the truck looks good , but dang boy whats up with that tailight ? I've been meaning to ask you . Do you know Jimmy Smith ? I believe he is from Olive Branch .
#22 |
Ole lady backed over the trash can and broke it trying to put it on the trailer,but it is 28 years o,she did it about 11/2months ago yea they do workRW
#23 |
Just messin with ya ! Last time a let a girl drive mine same thing hsappened .
