Old 07-18-2008, 03:45 PM   #1
1969 k/10
1969 k/10's Avatar
Axle help
I need help finding out the year of my front axle. I know for sure that it is a dana 44 but don't know what year it is. Any help would be appreciated.
1969 red k/10 with sb350
4.11 gear ratio, front disk, 3 speed automatic
1969 k/10 is offline   Reply With Quote
Old 07-18-2008, 03:49 PM   #2
LONGHAIR
Re: Axle help
There should be a code stamped on one of the axle tubes. It is usually on the top of the tube, near the center casting.
Open knuckle or closed?
Why do you need the year? parts issues?
LONGHAIR is offline   Reply With Quote
Old 07-18-2008, 04:10 PM   #3
1969 k/10
1969 k/10's Avatar
Re: Axle help
its a 1969 chevy and i need ball joints but the ones for 69 are a kingpin like one and i need ball joints.
And i found 2 codes stampd into the pumpkin and the axle tube ones are faded away
Old 07-18-2008, 05:40 PM   #4
LONGHAIR
Re: Axle help
Open knuckle?.......Can you physically see the axle shaft out near the ball-joints?
If so, it shouldn't be that hard. Try telling the parts guy that it is a few years newer. They only used the Dana44 up to somewhere around 1978. There is some debate about exactly what year the switch happened, but that won't effect what you need.
Old 07-18-2008, 06:13 PM   #5
Blazer1970
Blazer1970's Avatar
Re: Axle help
I am pretty sure that all Dana 44 and 10 bolt ball joints are the same '70 and up.
Blazer1970 is offline   Reply With Quote
Old 07-19-2008, 02:00 AM   #6
1969 k/10
1969 k/10's Avatar
Re: Axle help
how can i tell the difference between open and closed knuckle?
Old 07-19-2008, 06:29 AM   #7
Blazer1970
Blazer1970's Avatar
Re: Axle help
If you can look in and see the steering u-joint in the shafts it is open knuckle.
Old 07-20-2008, 01:44 AM   #8
1969 k/10
1969 k/10's Avatar
Re: Axle help
i can see it, which meens is open. Does that meen someone swapped it because i think 1969 had a closed knuckle?
Old 07-20-2008, 07:09 AM   #9
Blazer1970
Blazer1970's Avatar
Re: Axle help
Originally Posted by 1969 k/10 View Post
Does that meen someone swapped it?
Yes
Old 07-20-2008, 08:58 AM   #10
LONGHAIR
Re: Axle help
Yes, that is why I asked initially. The ones the parts guys tried to give you probably were the right ones for what is supposed to be in there.
It's ok though, the open knuckle front end is prefered anyway, it's a fairly common swap.
Old 07-21-2008, 01:47 PM   #11
1969K10
1969K10's Avatar
Re: Axle help
not that it matters, but I've been told '69 was a split year. the early models had closed knuckles & the later models had open knuckles.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 07-21-2008, 05:32 PM   #12
Blazer1970
Blazer1970's Avatar
Re: Axle help
All '69 Blazers came with open knuckle drum brake fronts. The Blazer was a mid-year introduction but I am not sure what they used on pickup trucks.
Old 07-22-2008, 12:53 AM   #13
1969 k/10
1969 k/10's Avatar
Re: Axle help
It has front disk but idk when the person swapped it.
