07-18-2008, 03:49 PM | #1 |
Freeeeee Mason...
Help... Sounds like a miss.
Okay, about 4-5 months ago my truck was running tip-top. Then reverse went out on my TH400. Then things seemed to snowball. Somehow a spark plug holder broke while i was driving one night, 7 miles from my house, and burnt three plug wires in half. I had no choice but to limp home, considering it was 3 am in a bad area to leave the 18k$ truck. So I limp her home. The next day I replace the spark plug wires. I take one off, and replace it exactly as it should be before continuing to the next. That would be the last time it really ran like it should. From that point on, when accelerating at low rpms, it sounds like it's missing a little. It sounds like its struggling so hard to get going. Once I'm at higher rpms, I can't hear it anymore. It may be the fact that I'm turning so many rpms that its not noticeable, but I'm not sure. A few nights ago I was driving it and noticed an exhaust leak, again... so right now I have the exhaust unbolted so it would be pointless to make a video with the obnoxious straight pipes. Anyone have any ideas? I'm really hoping that its possibly just a little off timing or a wire is switched on accident. Does it sound like anything else?
Edit 1: After checking, all my wires are correct, like I thought. Is it possible that this could be caused by a foul plug or wrong gaps? Edit 2: After checking 3 of the plugs on the left bank, most are looking fairly old and caked up. I'm going to buy a set of plugs tonight and put them in in a few days. If this doesn't work, on to the cap/rotor.
Daily Driver -2007 Chevy -Dark Blue Metallic -Regular Cab -4.8 V8 -4x4 Ongoing, Never Ending, PITA, Love of my Life -69 Chevy C/10, Camper Special -350/TH400 -Loudest System on the Board Last edited by Pl4yboy; 07-18-2008 at 04:48 PM. |
07-18-2008, 08:26 PM | #2 |
its all about the +6 inches
Re: Help... Sounds like a miss.
you may as well replace the cap and rotor too... with the plugs and the wires, that'd be a complete electrical tune up.
07-19-2008, 01:17 AM | #3 |
Freeeeee Mason...
Did all the wires when they got burnt, so they have less than 1000 miles on them. They're all good. The plugs look pretty fouled on the right bank. I'm sure they fouled when all the fuel was running in and no spark. I'll replace them next week sometime. I wont be running it much until then. I have to figure out the casting number before I go pick up the stuff though.
Daily Driver -2007 Chevy -Dark Blue Metallic -Regular Cab -4.8 V8 -4x4 Ongoing, Never Ending, PITA, Love of my Life -69 Chevy C/10, Camper Special -350/TH400 -Loudest System on the Board |
07-19-2008, 01:22 AM | #4 |
is the wires you put back on compatible with the ones you replaced. it seems to me tha if it ran fine before and all that happen is you burnt the wires then replaceing the wires should fix it. go ahead and recheck the firing order to make sure you have not crossed the wires.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
07-19-2008, 08:26 AM | #5 | |
Freeeeee Mason...
07-19-2008, 08:29 AM | #6 |
laying low
Yes. New plugs oughta fix it right up.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-19-2008, 08:55 PM | #7 |
Freeeeee Mason...
I'm really praying that that wink didn't mean sarcasm. I don't have a tool to measure plug gap so I have to wait on my buddy to bring his by.
07-19-2008, 09:26 PM | #8 |
Built 4 Speed
5 months isnt forever but bad fuel could be contributing to the fouled plugs.
ie: rust, water. IMO: zip ties placed correctly can make a very clean and NONGrounded Wiring harness.
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" |
07-19-2008, 10:56 PM | #9 |
Freeeeee Mason...
Well I've been running new fuel through it, it's been driven about 500 miles as is.
07-19-2008, 11:06 PM | #10 |
laying low
And no sarcasm intended by the winky. You need plugs!
Pl4yboy wrote: [Edit 2: After checking 3 of the plugs on the left bank, most are looking fairly old and caked up. The plugs look pretty fouled on the right bank. I'm sure they fouled when all the fuel was running in and no spark. ]
07-19-2008, 11:27 PM | #11 | |
Freeeeee Mason...
07-21-2008, 11:41 PM | #12 |
Freeeeee Mason...
New plugs went in today. It helped a little but I'm still bogged down it seems like. I'll try to make a video tomorrow so you guys can hear it.
07-22-2008, 06:20 AM | #13 |
you didn't burna valve did you?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
07-22-2008, 08:58 AM | #14 |
just a thought. but when you burt those wires you may have fried something in the dizzy when the wires grounded out on the manifold. could have affected the module or coil.
07-22-2008, 01:30 PM | #15 |
i changed everything on my truck also, put three sets of plugs ac delcos r44t
bosh platinums, auto lites was still the same bought wires cap and rotor contol module cleaned carburetor checked for burnt valves then it dawned on me to check the vacum advance it wasnt working put a new one on and now runs like a champ so you might want to check your vacum advance on your distribuetor. |
07-22-2008, 01:37 PM | #16 | |
Freeeeee Mason...
