Old 11-12-2002, 10:55 AM   #1
melloyello
melloyello's Avatar
coughing yellow truck
Where to start....sigh well every night on my way home from work my truck seems to sputter and cough and damn near die...The truck is warmed up and been driving great I've replaced the fuel filter and pump and had my carb rebuilt yet it still seems to fail ....I'm at my wits end here the engine runs like at top after I shut her down for a minute on the side of the road....anyone see what I forgot to check or fix? thanks for any replies
67 C/20 camper special 350
melloyello is offline   Reply With Quote
Old 11-12-2002, 11:21 AM   #2
melloyello
melloyello's Avatar
ttt
Old 11-12-2002, 12:26 PM   #3
ckhd
ckhd's Avatar
My 'burb was doing the exact same thing. When I'd drive it home (about an hour at highway speeds), then it would run terribly. It seemed like it was only running on 3-5 cylinders.
Anyway, it was the choke. I don't have it 'fixed' yet, but I do have the choke wired open so it won't do that. I have a long weekend this weekend and I'm going to see if I can properly fix the choke.
Just a thought.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 11-12-2002, 05:17 PM   #4
Hooter
My other Love
Hooter's Avatar
How's the ignition on your truck? do u have Hei? if soo check to see if the module is working good. Most autoparts stores will have a machine to check those. Also your coil might not be putting out enough power. If you have points i would stick a dwell meter on the system to see if you are getting good spark saturation
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-12-2002, 05:19 PM   #5
busterwivell
Mine was running terrible like that too, a few weeks ago. When I raised the hood with the engine running, I found that one of the plugs over a vacuum outlet on the carb was missing. Put on a new plug, life is good, again.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 11-13-2002, 11:01 AM   #6
melloyello
melloyello's Avatar
fuel problem fixed
It turned out to be a clogged fuel filter even though i replaced it the day before damn gas tank had a lot of rust and crap in it well its drained and cleaned out as well as the fuel lines(crossing fingers) I hope it doesn't start acting up again
