![]() Join Date: Jan 2001
Window regulator question
I few months ago I removed the innards from my doors and cleaned and lubed everything. I may have lubed the regulator too well, because when the window is down and I go over bumps, the glass tends to raise up 1-2 inches. Any suggestions?
Re: Window regulator question
Do both windows raise up when going over bumps?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
that sounds backwards does the crank turn |
I agree, sounds backwards. I've had mine want to drop a little on bumps. Simple fix was to take the crank handles off and put them back on with the knob down when the window was at the top.
Keepin it runnin!
On the regulator mechanism there is a steel "tab" that keeps the large curve rack gear aligned with the crank pinion gear. Over time that "tab" fatigues and allows the gears to slip. Cleaning them and greasing seems to make it worse, I know it did for me. 2 options; use a "C" clamp and bend that tab back into place. It doesnt need to move much. If that doesnt work, a new regulator may be in order.
Frank
1970 K-5 4X4 Blazer ![]() 1970 K-20 4X4 Long Bed ![]() "Liberty Means Responsibility, that is why most men dread it" |
