07-19-2008, 01:23 AM | #1 |
Shaved another one!!!!!
I'm sure this is what everyone was thinking from the title No more non-functioning A/C.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
07-19-2008, 01:25 AM | #2 |
Re: Shaved another one!!!!!
Heres a before pic...............
07-19-2008, 01:46 AM | #3 |
That looks clean. I am in the process of shaving my firewall
07-19-2008, 09:28 AM | #4 |
Engine n00b
educate the ignorant.. does this mean you lose your heater??
Whats the pro/con of shaving? I like the clean look for sure. |
07-19-2008, 11:44 AM | #5 |
PROJECT 7DEUCE
He still has a heater just no a/c...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-19-2008, 12:52 PM | #6 |
chevelito
very nice!
New deadline...when my son can drive. Aloha from Honolulu, HI |
07-19-2008, 01:01 PM | #7 | |
I just really like the look of a clean engine compartment.
07-19-2008, 01:48 PM | #8 |
you got a link to the hot rod heater??
does look clean, and IMO the only way to go |
07-19-2008, 02:28 PM | #9 |
Trucks N Tranzams
Here are several. I like a clean engine compartment as well.
If it wasn't so hot here I would have one as well. I have Vintage air and it makes for a clean engine compartment. http://www.southernrods.com/categori...oduct-867.html http://wheels-of-time.com/streetrodh...trolvalve.aspx http://performanceparts.com/part.php?partID=795
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
07-19-2008, 03:24 PM | #10 |
how would you go about leaving the heater box in the engine bay but just do away with the ac box. ive gotten rod of the ac compressor but still have the ac in the bay but wanna ditch it but not sure which hoses to keep the heater hooked. anyone be able to shed some light on that?
07-19-2008, 05:48 PM | #11 |
I bought mine at a heavy machine repair place. I'll post pics later.
07-19-2008, 05:50 PM | #12 | |
You need the supply hose off the waterpump and the return hose to the intake.
07-19-2008, 06:00 PM | #13 | |
You would have to cover the opening and reopen the hole for the smaller heater box. Or, weld in the part of the firewall that is for the heater only box. Or, cover the area completely then drill two holes for the heater hose block that would mount to the firewall accepting the hoses from the engine. Or, keep the stock heater/ac box and only use the heater ports. (just the two hoses that hook to your intake manifold and water pump. (usually look about 1/2-3/4 in hoses)
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
07-19-2008, 07:06 PM | #14 |
Less work but it helps get around your huge A/C box is to get a delete panel like I did on my GMC.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
