Old 11-12-2002, 12:16 PM   #1
Scottri
Scottri's Avatar
Bedside.
I hope this doesn't seem like a stupid question but here it is.
What is involved with removing and replacing a bedside on a long bed fleetside truck? Does it involve cutting and welding or can it be done by a weekend amature?
Thanks,
Scott
1969 GMC 3/4 Ton Long Bed Fleetside
350, 4 speed manual, P/S, P/B, Edelbrock 1406 Carb
Beaverton / Portland Oregon
Scottri is offline   Reply With Quote
Old 11-12-2002, 12:19 PM   #2
slam33
slam33's Avatar
It's all bolted together and you can do it in a weekend
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 11-12-2002, 01:46 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
There is also a small weld you'll have to cut. It is located where the bedside meets the rear bed brace, right by the tailgate hinge. Can easliy be cut with a die grider or angle grinder with a thin cut-off wheel. Also, expect to have some problems removing some of the carriage bolts that hold the sides down. They are most likely rusty and the heads will spin when you attempt to loosen them. Just giving you fair warning..... but you may get lucky. Might soak them good with WD-40 or Liquid Wrench before attempting removing them.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 11-12-2002, 02:12 PM   #4
Scottri
Scottri's Avatar
Thanks guys!
Hey Slam, where do you live in Long Beach? I grew up there. I went to Poly high then Millikan. Graduated in '81. I grew up down near Bixby Park near 3rd and Temple. I moved up here to Oregon about 8 years ago and don't make it back often.
Scott
Old 11-12-2002, 08:12 PM   #5
VDOG
Grand PooBaa Member
VDOG's Avatar
Yo Slam! Im in LA, about 10 miles from Long Beach.
Got any spare bedside parts? Mainly the driver side for a longbed?
VDOG is offline   Reply With Quote
