1962 Chev 3/4 ton 2WD -- Towing ?
My grandmother is giving me her '62 Chevy 3/4 ton. I am sure I will have numerous questions for the forum once my sons and I start the restoration process, but my immediate issue is I have to trailer it from TX to CA.
Does anyone know the curb weight of the truck or know where I can find the info? Any experiences with UHaul car hauls? I will be pulling it with a FORD F150 FX4 Super Cab 5.4L. Thanks |
1961 crewcab
Re: 1962 Chev 3/4 ton 2WD -- Towing ?
I dont't know for sure , but I think 4-4500 is a safe guess.
#3 | |
Hollister, CA.
![]() Join Date: Sep 2006
![]() Anyway, I have my own trailers, but I have pulled U-hauls before and they work very well....Nice tire tie-downs with rachets, good ramps, etc. Just bring a can of WD with you, to lube the rachets...U-haul never seems to never lube those.... Later
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 07-19-2008 at 01:59 PM. |
UCA63
Short step 4000 lbs
Long bed,like jonz said 4500 would be a safe bet T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
IF i was you, try to go with penskye or ryder. I had a u-haul trailer awhile back that someone else wrecked and they gave to me. couldn't travel above 45 without the death shake. 29 hour drive i made with a death grip on the wheel of the dodge trying to get it home. Turned out the front axle on the trailer was 3 inches to the driver side and passenger side on the front axle was shoved back almost two inches causing it to want to steer itself.
I wish my grandmother had a 62 C20!
![]() As the others have said, I'm sure your F150 will pull the load alright. I've had this much weight behind my 77 C10 and it only has a 250. Are you going with a a 2 wheel dolly or a double axle flat trailer?
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
i would use a flat trailer, because that is less wear on the truck that you are pulling, and it is just better, IMHO
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
