Old 07-19-2008, 06:03 PM   #1
hotrodsbyray
Unhappy HELP - i need 57 door info
put new hinge pockets, running boards and outer cab corners on my 57. fit great - measurements good.
the lower rear corner where cab corner meets running board was shaped funny and had a good 10 pounds of bondo to "smooth" and "customize" it.
the door on the driver side had been modified to fit over the rocker, not tuck down close like factory.
my PROBLEM - when i put the door on to check fit, the modified lower door fits over the rocker and wont fit against the rear edge now that the body iis back stock!
Can somebody pretty please measure a stock door to give me some idea how screwed up the door i have is?
i need a measurement at about the middle of the window. simply hook a steel tape at the lower edge, loosely fit it to the body and up to the top edge of the door. or whatever landmark works.
i also need to know how long the door is from front edge to back edge along the bottom so i can figure out how off my door is.
dont even ask about the passenger side! it looks like it was wrecked at some point in the past, and put together with bondo and globs and globs of stick weld. the cab corner is no where near fitting yet
hotrodsbyray is offline   Reply With Quote
Old 07-19-2008, 10:54 PM   #2
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Re: HELP - i need 57 door info
My truck is in pieces so a good landmark is not available for the window measurment unless you can desribe what you're looking for better. But, the lower measurment on the door from front to rear is an even 38".
It is not dented nor has it been bondo'd.
Kenny
87Lowrider is offline   Reply With Quote
