Old 11-12-2002, 01:26 PM   #1
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
Angry HEI...New or Junk Yard
Well, I need to dig into the vault of wisdom, again. I am having ignition problems again on my '71 C-20 350. Yes, I have points. Yes, I have finally broken down and have decided to install electronic ignition. My question is, should I buy new or pull a unit off a bone yard truck and just slap some new parts on it. The NAPA guy said he could get me squared away with new parts for under $50 if I already had a distributor.
If I go with the Junk Yard Dis., do I need to look for certain years? avoid certain years?
Thanks everyone!
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 11-12-2002, 01:56 PM   #2
mikep
Used to have a truck
mikep's Avatar
A new one will set you back a bit over ahundred and then you wont have to deal with sloppy bushings.
A bit of advice though. I always thought it was a bunch of crap untl I did it. I was having top end and under load misfires with my HEI equipped engine. Played with the carb a bit and still the same thing. Then I replaced the 16 gage wire I had going to it with a 10 gage wire feeding directly from the fuse block and my truck runs 100% better. No misfires at all. That HEI draws more current than I thought it would.
No truck :-(
mikep is offline   Reply With Quote
Old 11-12-2002, 02:05 PM   #3
matt67350
matt67350's Avatar
Thumbs up
Get a New One, and you'll be very happy:p
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 11-12-2002, 02:14 PM   #4
Scottri
Scottri's Avatar
I bought mine from a junkyard for about $40.00 and it's worked great.
Scott
1969 GMC 3/4 Ton Long Bed Fleetside
350, 4 speed manual, P/S, P/B, Edelbrock 1406 Carb
Beaverton / Portland Oregon
Scottri is offline   Reply With Quote
Old 11-12-2002, 02:25 PM   #5
barn9
Half a bubble off!
barn9's Avatar
I got my Accel HEI at the bone yard for $45. It was almost new, came off a TransAm that had been rolled. If I had known how much of a difference there would be, I'd have done it long before and been happy to pay more too. HEI and an internally regulated alternator did wonders for my truck, I would reccommend both changes to anyone.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 11-12-2002, 02:26 PM   #6
JimKshortstep4x4
Smile
Unless you have access to a distributor machine, I would recommend that you buy a new one. They have some pretty good deals on distributors now and they even have them curved if you like.
I have a distributor machine, so I can get by, buying used ones, but I still end up with time and parts into them.
Jim
Old 11-12-2002, 04:00 PM   #7
cheyenne10
cheyenne10's Avatar
new dist.
Ok I also what to buy a new one. Where do I get one and which one should I buy and price shjould be? (best bang for buck). Mine is stock crate 350.
Bob
cheyenne10 is offline   Reply With Quote
Old 11-12-2002, 04:36 PM   #8
treefrog
HEI
Go New. If you go used, you may end up with compatability issues. I bit the bullet and went from 9.2 city to 11.9. Not much, but it's with 27" tires and 4.11 rear. TF
treefrog is offline   Reply With Quote
Old 11-12-2002, 04:36 PM   #9
mikep
mikep's Avatar
I think summit racing has them for around $110
No truck :-(
Old 11-12-2002, 04:55 PM   #10
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
I just got a brand new Proform HEI distributor from www.summitracing.com. It was $157 and its RED to match my RED plug wires. Dont forget to get new HEI style wires as well. One other thing that I will also be getting is this summit HEI power pigtale. It has the right plug end for the 12v you need to run to your distributor and has an 8in lead. I figure might as well for 5 bucks. Here are the links for the distributor and the pigtale plug:
http://store.summitracing.com/partdetail.asp?part=21377
http://store.summitracing.com/partdetail.asp?part=11396
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
