Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-19-2008, 07:23 PM   #1
PA-IndianRider
PA-IndianRider's Avatar
Can This be FIXED? Edelbrock Cross Ram manifold
Saw this at a swap meet today..... looks like someone over did it or DROPPED this Edelbrock Cross Ram Manifold.
Can this be fixed???
My concern is that the broken "ear" is in the front where the water jacket is.
Need someone's EXPERT opinion????????
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 07-19-2008, 09:00 PM   #2
69trk
69trk's Avatar
Re: Can This be FIXED? Edelbrock Cross Ram manifold
I had a dart single plane intake that cracked on the front from tightning to specs, looks like the same spot. Called dart and they said to mail it in and they will send me another one, but they told me that they would repair it as if it was no problem. Does the guy have the piece that broke off?
69trk is offline   Reply With Quote
Old 07-19-2008, 11:07 PM   #3
PA-IndianRider
Nope..... which will compound matters..... sure I could pick this up cheap enough to have it repaired..... always liked this type of manifold.
Sent the pics to my cousin who works for Miller Welding and see what he says
John aka "Milner"
Old 07-19-2008, 11:47 PM   #4
royo
royo's Avatar
Machine shops weld alum heads . maybe one could build up the weld on that and redrill the hole
nickle and dime
royo is offline   Reply With Quote
Old 07-20-2008, 01:54 AM   #5
Captainfab
60-66 Nut
That should be an easy fix for an experienced welder. I've fixed similar problems many times without the missing piece.
Old 07-20-2008, 05:04 PM   #6
71Dragtruck
71Dragtruck's Avatar
Ya that can be fixed easy, had that fixed before on the center bolts.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 07-20-2008, 07:18 PM   #7
Alex1
Alex1's Avatar
Yup easy fix. Had a shop do something like that for an intake once.
Alex1 is offline   Reply With Quote
Old 07-20-2008, 07:33 PM   #8
PA-IndianRider
After hearing the manifold could be fixed I called my brother-in-law who was going to the swap meet today.... caught him before he left.... drove down to his place.... gave him the money.... told him "where" to find the manifold..... and away he went....
only to find out the "seller" did NOT return to the swap meet today..... Bummer!!! That's how my luck goes.... they'll be another swap meet at Canfield, Ohio again in the Fall (3 x a yr). So maybe I'll get another chance to score the "cross ram" I have always wanted.
John aka "Milner"
