Old 07-20-2008, 11:21 AM   #1
1972CST
1972CST's Avatar
Almost ready for a motor
This is the last progress I made before haveing a litte out-patient surgery. I have not done much since. A friend of mine told me about useing oven cleaner to clean a frame and boy was he right!!!! The paint is just Rustoleum semi-gloss black, I hope it holds up.
1972CST is offline   Reply With Quote
Old 07-20-2008, 11:24 AM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Almost ready for a motor
Nice D-ring type setup, Do you think the part tied to the frame is enough?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-20-2008, 11:56 AM   #3
1972CST
1972CST's Avatar
I think so? My uncle had that put in right after he bought this blazer in74'. From what he tells me, the tube is the piston out of hydrolic cylinder(really thick walled) and the d-ring "hangers" were cut off of some kind of heavy equiptment. The tube is welded all the way around at both ends to the frame.
Old 07-20-2008, 06:28 PM   #4
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Looks Good 1972CST! Some day I will get that far on mine! I also like using oven cleaner for various projects.
Just a note of caution for anyone that wants to try the oven cleaner. It eats many types of paint! It also can eat masking tape adhesive.
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 07-20-2008, 06:40 PM   #5
Big Block
Big Block
Big Block's Avatar
Your frame looks really good. Did you use any type primer on the frame before you painted it?
Big Block is offline   Reply With Quote
Old 07-20-2008, 07:32 PM   #6
1972CST
1972CST's Avatar
No primer, from what I under stand Rustoleum is compatible over bare metal or primer? We shall see! Thats a nice blazer you have.
Old 07-20-2008, 07:35 PM   #7
1972CST
1972CST's Avatar
70gmcjimmy, do you have a build thread? That is going to be a cool truck w/ 2001 goodies underneth.
Old 07-21-2008, 02:31 AM   #8
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Yeah that would be cool to update to 2001 stuff under my Jimmy, but its a little out of my budget. My Mom drove my 70 GMC from 1971 to 2001. Her age and a broken flexplate brought the truck to me mid 2001.
No, I don't have a build thread as my updates are rare. I recently purchased a good running '89 Suburban (cheap) that I am considering using the tbi 350 and drivetrain to get some mileage, got new body mounts installed and am fitting new carpet. I don't want to hack on Mom's Jimmy too much, but I do intend on it being able to be a daily driver, along with my other trucks.
Thanks for asking---DAC
Old 07-21-2008, 09:47 PM   #9
1972CST
1972CST's Avatar
I gotcha...I guess I had a dumb blonde moment! I thought 1971-2001 under rebuild was 71 on 01 frame
Old 07-25-2008, 12:53 AM   #10
truckster
truckster's Avatar
That is amazing! It looks like you had the frame blasted. Did you have to do a lot of scrubbing?
truckster is offline   Reply With Quote
Old 07-25-2008, 09:35 AM   #11
1972CST
1972CST's Avatar
no, just oven cleaner overnight and a 1500 psi washer the next day.
Old 07-25-2008, 12:12 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks pretty goood...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
