Old 07-20-2008, 01:35 PM   #1
oz's74 project
sittin sidewayz
have an 04 silverado, that i have lowered with a 2/4 groundforce kit,recently noticed the driver side sits lower then passenger side anyone else have this problem? what can cause this please help
oz's74 project is offline   Reply With Quote
Old 07-23-2008, 08:19 PM   #2
YOLO
Custom Truck Lover!
YOLO's Avatar
Re: sittin sidewayz
That is a common chevy/gmc problem. The gas tank is on the drivers side.
Squarebody guy
YOLO is offline   Reply With Quote
Old 07-23-2008, 08:45 PM   #3
bdydrp97s10
bdydrp97s10's Avatar
Re: sittin sidewayz
yes it is common. weight of the driver and gas tank weight all on one side makes tehm lean
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333
bdydrp97s10 is offline   Reply With Quote
Old 07-23-2008, 11:21 PM   #4
ton*loc
ton*loc's Avatar
Re: sittin sidewayz
you gotta "lean with it" like the song says
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 07-24-2008, 11:13 PM   #5
kevinr1970
Re: sittin sidewayz
Yes it is common; called the "Chevy lean".
But is the gas tank enough to make that much difference?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 07-30-2008, 10:12 AM   #6
shyboy
Re: sittin sidewayz
you know i just noticed the same thing on my 03 sierra but i still havent lowered it yet. Did you noticed this before you dropped it or after?
shyboy is offline   Reply With Quote
Old 07-31-2008, 09:21 PM   #7
oz's74 project
Re: sittin sidewayz
i noticed it after the drop
Old 08-26-2008, 09:42 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: sittin sidewayz
gas weight 7.3 pounds a gallon... multiply that by what, 30 gallons? 219 pounds with a full tank... plus 200 or so pounds for a typical male driver...
I could see that makin it lean a bit.
Old 08-27-2008, 09:28 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: sittin sidewayz
It is very common, you just didn't notice it before the drop. on my 06 Silverade CC, I had to set one shackle a hole higher than the other. Mine was so bad I couldn't even tow a small trailer without it bottoming out.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-27-2008, 11:18 AM   #10
WELD4DAYS
Re: sittin sidewayz
I have a 2002 Silverado with a DJM 4/6 drop.The front driver side was almost an inch lower than the passenger side. I have the 4inch drop lower control arms.I made a spacer about 3/4 inch thick to sit down in the cup.Then I installed the spring like normal.It helped alot but it still sat a little lower.I also tried a 1 inch block on the rear of the passenger side.They both worked but it still never sat level.It bugged me forever because I knew it didn't sit level.Good luck.
WELD4DAYS is offline   Reply With Quote
