Old 07-20-2008, 02:31 PM   #1
lifted 75 k5
lifted 75 k5's Avatar
transfer case to trans
will a np 205 transfer case bolt up to a turbo 350 trans and what do i have to do to make it work
LIFTED OR LOWERED EITHER WAY STOCK SUCKS
75 Chevy blazer
86 trx 250R
1990 Ford Ranger 2wd prerunner project
lifted 75 k5 is offline   Reply With Quote
Old 07-20-2008, 10:56 PM   #2
1969 GMC
1969 GMC's Avatar
Re: transfer case to trans
that was the factory setup in 69-72 Chevy K series, and I believe also in some 1980 trucks. Find a complete setup
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 07-21-2008, 09:13 AM   #3
tobiahr
tobiahr's Avatar
you can even use the 2wd transmission if you change to the short output shaft. it was covered on extreme 4X4 this weekend. cant remember all the details but i know it can be done
tobiahr is offline   Reply With Quote
Old 07-21-2008, 11:04 AM   #4
lifted 75 k5
is there just an adapter because thats what i have been hearing from a couple people
75 Chevy blazer
86 trx 250R
Old 07-21-2008, 11:20 AM   #5
tobiahr
tobiahr's Avatar
you have to get the 4wd coupler? adapter? not sure what is called but it takes the place oth the tailshaft housing on a 2wd transmission. are you putting the np 205 transfer case on an existing 4wd model or converting a 2wd? if you are converting there are other things you should change also. http://www.chuckschevytruckpages.com/2wdto4wd.html is a good starting point
Old 07-22-2008, 01:45 PM   #6
lifted 75 k5
no its a 4wd i have a np 203 transfer case and the chain is loose and the low gear chain is also broke and my truck will see a little crawling and a lot of mud but i just want a strong reliable case and my driveshaft just blew out the rear going down the high way so i have to replace that also so i just want to do it all at once
75 Chevy blazer
86 trx 250R
Old 07-22-2008, 02:10 PM   #7
tobiahr
tobiahr's Avatar
ok the 205 will NOT bolt up to the tcase adapter you currently have . They have a different bolt pattern. you may want to make sure the spline count on the original tcase matches the spline count on the new tcase, the yokes match (same ujoint size), and the distance from the front to the back matches but other than that i cant think of alot of variations between the tcases other than the bolt pattern. the spline count and yoke size may be different because of different applications. read this http://www.high-impact.net/transmiss...ar/Tcase_NP205.
you can find a th350 to np205 adapter here http://www.extremegearoffroad.com/st...roductid=17182 but it is a little pricey.
also see here http://www.4wheeloffroad.com/techart...ase/index.html
this article covers most of the questions you've been asking
Old 07-22-2008, 09:19 PM   #8
lifted 75 k5
thanks alot do u know if the t case came off a th350 if it will be any different
75 Chevy blazer
86 trx 250R
Old 07-23-2008, 08:54 AM   #9
tobiahr
tobiahr's Avatar
the tcase isn't what changes. there is an adapter plate between the transmission and tcase that mates the two together. it you could get the tcase with that adapter it would work. other wise the np203 adapter that is currently on your transmission will not bolt up to the np205.
Old 07-24-2008, 12:58 PM   #10
lifted 75 k5
ok so the 205 is off a turbo 350 so it should have the right adapter plate correct
75 Chevy blazer
86 trx 250R
Old 07-24-2008, 01:14 PM   #11
tobiahr
tobiahr's Avatar
i want to say yes but i'm not sure if we are talking about the same part when we say adapter plate. it should be the piece in this pic
if it has four holes on the transmission side and six on the tcase side it should work
basically you bolt this to the tranny (as shown in this pic) and then bolt the tcase to it
Old 07-24-2008, 01:36 PM   #12
lifted 75 k5
ok i see what u are saying so the piece should still be on the transmission
75 Chevy blazer
86 trx 250R
Old 07-24-2008, 01:46 PM   #13
tobiahr
tobiahr's Avatar
it usually is left on there when the tcase is removed...it depends on who removed it
Old 07-24-2008, 03:07 PM   #14
lifted 75 k5
ok thank you for your help i really appreciate it
75 Chevy blazer
86 trx 250R
Old 07-24-2008, 03:09 PM   #15
tobiahr
tobiahr's Avatar
I will see if I still have my shop manual tonight and scan you the relevent pages if there still in there
Old 07-24-2008, 03:24 PM   #16
hdflstf
hdflstf's Avatar
I have pictures of my NP205, adapter, coupler that goes with my TH350 on this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=266278
First adapter picture is at post 13.
You will need the adapter (factory part pictured), the coupler, and perhaps the trans output shaft if it is different (I don't know on this).
hdflstf is offline   Reply With Quote
Old 07-24-2008, 04:21 PM   #17
lifted 75 k5
oh ok t see what i am goint to look for on the case now i really appreviate the help
75 Chevy blazer
86 trx 250R
Old 07-31-2008, 01:14 PM   #18
SUB602
SUB602's Avatar
I just picked up my Th350 to Np205 adapter with shifter and 27 spline coupler from Steve at Backwoodsparts.com. Check him out he may have what you need. Oh by the way i only spent $168.00 incl shipping.
www.SlammersKustoms.com
98 GMC K1500 Suburban
75 K-5 SB350/TH350/NP205
74 K-5 Convert to 2wd and bag her
Authorized dealer for the Dropmember, Built by PorterBuilt Street Rods
SUB602 is offline   Reply With Quote
Old 08-03-2008, 07:40 PM   #19
lifted 75 k5
ok thanks i will look at that after i go look at the case to see what i need
75 Chevy blazer
86 trx 250R
