Old 07-20-2008, 07:50 PM   #1
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Trying to ID a 3/4 ton front axle
Hey everyone, got this axle today, not sure what it is, It doesnt look quite like a Dana 44, the tubes are bigger, but it doesnt quite look like a dana 60. Anyone know what it is, it is out of a 77 Chevy 3/4 ton, the rear end is a 14B FF, and the T-case is a 203 mated to a TH350 4bbl original.
Going to possibly stuff this axle under my 72 Blazer to make it an 8 lug.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 07-20-2008, 08:53 PM   #2
msgross
msgross's Avatar
Re: Trying to ID a 3/4 ton front axle
had to do it...sorry...
I know my 10 bolt has a 3" axle tube and most Dana44 have a 2.75" tube. Really need to see the diff cover though.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-20-2008, 09:05 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Does this help? http://www.coloradok5.com/axleguide.shtml
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-20-2008, 09:07 PM   #4
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Sounds like a GM 8.5" 10 bolt. IIRC, '77 was the switchover year from the dana 44.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 07-20-2008, 09:20 PM   #5
MrBeast
high-Tech Red Neck
MrBeast's Avatar
I accidentialy double posted before putting in pics, here you go.
I am pretty sure it is a 10 bolt, I just wonder if it is worth the while to stuff it under my blazer, also if it is the right width, or if I will have to modify it.
Or if I should just immediately junk it because I don't want the headache. Myself and 10 bolt rears don't really play well together.
Old 07-20-2008, 09:48 PM   #6
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Yep, it's a 10 bolt. IMO, it's weaker torque- capacity wise than a 44, but stronger tough- truck wise due to the bigger tubes.
If all you are after is 8 lug, just swap the caliper brackets, calipers, hubs & rotors. It should all bolt right on. The 8 lug may have bigger pistons in the calipers, so different hoses, and maybe a master cylinder, may be needed. I ran into this on an '80 K20 axle once.
Old 07-20-2008, 09:55 PM   #7
MrBeast
high-Tech Red Neck
MrBeast's Avatar
If the ends will swap out, then I will just stuff em on, that will make things easy enough. From what I can tell they only offered a 4.10 and a 4.56 in 77, so it will probably be a 4.10. I think my blazer has 3.73's
Old 07-21-2008, 08:50 AM   #8
msgross
msgross's Avatar
should be able to pull everything off from the spindles outward and swap.
The Garage:
Old 07-21-2008, 05:29 PM   #9
Blazer1970
Blazer1970's Avatar
You will need to swap the spindles.
Blazer1970 is offline   Reply With Quote
Old 07-21-2008, 05:50 PM   #10
70rs/ss
70rs/ss's Avatar
Yeah the 3/4 and 1/2 dana 44's are the same except the spindle out. If the spindle out will swap onto the 1/2 dana 44, I'd do that if you want to abuse it? If just a driver with occasion off road, that 10 bolt will last, and the front axle is a bolt in deal, oh heck if you do this then you need to do a gear swap, nevermind, put the 10-bolt spindles onto the 1/2 ton 44 and you have the best of both.
70rs/ss is offline   Reply With Quote
Old 07-21-2008, 06:39 PM   #11
msgross
msgross's Avatar
that's what I meant,,,"from the spindles outward" to include them...
But to answer your question, yes, it will bolt right under our truck. Double check the spring widths. You sill have to use all the hardware off it though (U-bolts, top plates). If you are swapping the rear then you should check gear ratio's... best way is to pull the diff cover off and read the numbers on the large ring gear. Should have a stamping like 41:11 or 41 divided by 11 = 3.72727272 (repeating of course) or otherwise known as 3.73 ratio. I found that the banjo bolt on the brake lines is metric on those and the driveshaft is 1" inboard from the DANA44
The Garage:
