07-20-2008, 08:24 PM | #1 |
5 lug to 6 lug rotors? with a pic!
Would it really be that simple is to switch out 5 lug rotors to 6 lug? Are the spindle's the same diameter?
-josh Last edited by haeusser; 07-21-2008 at 08:59 PM. |
07-20-2008, 09:29 PM | #2 |
Re: 5 lug to 6 lug rotors?
If you use 6-lug conversion rotors from the board supporting vendors, they're a direct swap.
07-20-2008, 11:31 PM | #3 |
its all about the +6 inches
welcome to the board josh!
I got an old army buddy up in fremont. |
07-20-2008, 11:53 PM | #4 |
Tasty Cakes!
I think this is a first! Wanting to go from 5 to 6? It's usually the other way around. Got some 6-lug wheels you've got ur eye on or something?
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
07-21-2008, 09:52 AM | #5 |
Yep, they're a little pricey, but direct swap. I've got ECE's on my truck.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-21-2008 at 09:52 AM. |
07-21-2008, 11:45 AM | #6 |
who's your army buddy in fremont??
I found a nice set of wheels from a friend, really cheap, but there 6 lug. I already have the rear axle's, just need 6 lug rotors. My local parts store said they have 6 lug rotors for a 71 for 75 a piece. Those from the parts store wont be a direct bolt in? Who has the direct bolt ins?? Thank you for the replys!! |
07-21-2008, 12:00 PM | #7 |
Project Junkie! Fishing Poor!!
The six lug rotors at the parts store are probably for a 4x4. All parts stores that I know of do not get the conversion rotors. They are manufactured by different companies that specialize in conversion parts. Mainline parts stores buy from direct replacement manufacturers. We have them in stock. Here is a link if you are interested: http://www.classicheartbeat.com/67-7...suspension.htm WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
07-21-2008, 01:27 PM | #8 |
Tasty Cakes!
We need pics of the wheels
07-21-2008, 02:40 PM | #9 |
Welcome to the forum..... Be careful to check out pricing before you commit to the 6 lug wheels. the rotors for 6 lug wheel were close to $200 apiece and only available in 1 or 2 places the last time I checked. The 5 lug versions were off the shelf anywhere at about $50 apiece. And yes, they do swap direct without any mods. Good luck!
07-21-2008, 02:57 PM | #10 |
They are waaay cheaper now. Mine were $80 ea. That is still a lot, but much cheaper than changing axals.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
07-21-2008, 03:23 PM | #11 | |
07-21-2008, 03:42 PM | #12 |
Well, it has been over a year since I swapped mine out and I used ECE front and rear. I remember talking to someone at ECE because I couldn't believe the rotor price. He told me the 6 lugs rotors were proprietary and everyone had to buy from the same source. Maybe that has changed??? Anyway, thats the main reason (plus the obvious better choice for wheels) I decided to swap over to 5 lug. Thats also a good example of why this forum works, someone may have different info or ideas.
07-21-2008, 03:43 PM | #13 |
I checked ECE earlier and they were $89 each for non drilled rotors. The drilled rotors are $160 each.
http://www.earlyclassic.com/catalog.aspx
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-21-2008, 03:58 PM | #14 |
What is the rear in the truck (5 or 6 lug, year, etc). The reason I ask, is that if it is a 5-lug there is a chance that the housing is the longer housing (67-70ish was narrower than the 70ish-72 housing) and the 6-lug axles from the narrow version will not fit properly in the wider housing. If they are aftermarket axles for your housing then my comments are moot. Just wanted to point that out, as the rear end/axles swap if they are mismatched, and the cost of the front rotors could end up making the swap backwards to 6-lug not as cost effective as buying new 5-lug wheels in the same style as the "good deal" on the 6-lug wheels. All 2wd truck rears(to my knowledge, but I am not an expert) with 6-lug axles were from 67-70 years. The rears seemed to change mid-year according to some folks, so if it is a 70 model rear, then a quick measurement will be the only for sure way to know. So basing my thoughts on my guesstimations, you have a set of older used 6-lug axles that will be too narrow to swap into a wider 5-lug housing, so you'll also need to buy new axles for about $300, along with the $$$ for the rotors. Good Luck either way, hope my ideas make sense and help??
One other thing and i think most guys here will agree, the 6-lug rotor is a special deal only offered from a few vendors, so if in the small chance you swap and later need another rotor ASAP due to some unforseen problem, you'll need to order and wait as a replacement isn't available at the locl autozone. I know not too many chances of it happening, but Murphey kicks my butt a lot, and that being said I'd be driving somewhere in BFE, and have a failure, may not happen but just yet another FYI from the worry wart. Last edited by 70rs/ss; 07-21-2008 at 04:09 PM. |
07-21-2008, 04:04 PM | #15 |
Tasty Cakes!
That's a good point 70rs/ss... I'm keeping my truck 6-lug, but if I had to do it all over again, I'd probably go to the 5 lug.
07-21-2008, 04:14 PM | #16 |
I added a little more to my post after you read it rivited1, so I hope my changes didn't effect your thoughts? I was trying to swap my 99 Tahoe to 6-lug as I had a set of wheels from my 05 Yukon XL that I rolled and it was never going to happen. In the 89-99 2wd trucks there was only a 5-lug, but the 00 and up went to a 6-lug, I tried and tried to make it work, but rotors are a one thing deal and no one would sell me a blank 5-lug rotor (made for my application without the holes for the studs so I could drill with the 6-lug style). I have a very nice set of 6-lug, 20" wheels and no where to go with them. i may build a truck (67-72) with 6-lugs just so I can use them, but the cost of the swap is keeping the wheels in storage for now.
07-21-2008, 04:26 PM | #17 |
I have a whole 67 rear end that im swapping out. 3.55 gear i think. Truck was a 3 on the tree so im expecting a lower gear. I would love to stay 5 lug, but the wheels were too good of a deal to pass up. We have a 67-72 junk yard behind our shop, so having tons of parts laying around helps, just didnt have any 6 lug rotors. I have 6 lug front drum brakes, but cmon!!
Thanks for all your advice and fast reply's, im ordering ece rotors as we speak!! thanks again!! |
07-21-2008, 06:22 PM | #18 |
Cool I wasn't sure if you were doing a complete rear swap or just the axles (pretty common way to go from a 6-lug to 5 or back in your case). With the prices coming down on the 6-lug swap rotors, just buy a spare for an "incase of emergency" swap?!
Good Luck, and BTW we like picts, so when you get it together with the wheels, post em up! Last edited by 70rs/ss; 07-22-2008 at 12:06 PM. |
07-21-2008, 08:58 PM | #19 |
07-22-2008, 05:53 AM | #20 |
Tasty Cakes!
Those are nice lookin... are you sure they will fit over the front hub? Might wanna check that b4 u switch to the 6 lugs.
